How to Make Your Swamp Cooler More Effective
red swamp cooler
Using a swamp cooler can keep your home cooler during those hot summer months without using a lot of electricity like an air conditioning system. Mostly used in warm, dry areas of the country, a swamp cooler works through the process of evaporating water. The water evaporates and is then blown into the air for a cool mist. A swamp cooler does not work efficiently when there is a lot of humidity in the air already, so follow these steps for reducing the humidity in your home so that the swamp cooler will work more efficiently.
Step 1 - Use a Dehumidifier
If your home is humid or you live in an area where the humidity is fairly high in the summer, such as Florida or Louisiana, you should use a dehumidifier to keep the levels in your home constant. If there is a lot of humidity in your home, then the swamp cooler will not function properly. You can position the dehumidifier near the intake for the swamp cooler for best results.
Step 2 - Open the Windows
An easy way to keep the humidity down in your home is to open the windows up about 2 inches. This will help create a cross breeze that moves the air. When the air is allowed to move freely, it keeps the moisture in the air less compact and more able to escape. Make sure the windows you open are across from each other in order for that cross breeze to develop.
Step 3 - Use Plants
Some house plants have a natural tendency to dry the air out. Some forms of cactus are an example of this. Situate several small potted cacti plants around your home and you will notice a big difference in the humidity in the air. A Boston Fern is also another great option for drying out the air. Not only that, but they will also keep the air clean and free of a lot of impurities.
Step 4 - Keep Pads Moist
When you operate the swamp cooler, you must always make sure that the wet pads are actually wet. The swamp cooler blows cold air because the warm air flows over the cooler damp pads, thus exchanging the heat for colder air. If the pads are not wet, then the moisture will not evaporate causing a cool mist.
Step 5 - Keep Tank Full of Water
One of the problems that many people fall into when running a swamp cooler is that they do not keep enough water in the tank. Each week, check the tank to make sure there is enough water to keep the pads moist.
Step 6 - Let Run Before Fans
When first starting the swamp cooler, make sure to let it run for about 15 minutes before you turn on the blower motor. This will get the water flowing and the pump primed enough to keep the pads moist.
Step 7 - Keep Swamp Cooler Maintained
There are plenty of things inside the cooler that can go wrong if not taken care of properly. Spend some time before the season to do basic maintenance as well as winterizing the unit before shutting it down for the season.
