How to Paint a Swirl Plaster Ceiling
Painting a textured ceiling.
  • 24 hours
  • 150-300
Safety glasses
Gloves
Face mask
Standard paint rolling system
Painter's tape
Butcher's paper
Painter's tarp
Safety glasses
Gloves
Face mask
Painter's tape
Butcher's paper
Painter's tarp
Painting a plaster ceiling with a swirl plaster finish or texture is a full day process unless you have a power sprayer. This article will list some methods of applying paint to a textured plaster ceiling and some things to be sure to do to make cleanup as easy and effortless as possible.
Plan for Cleanup Ahead of Time
There are a few things you can before you start painting to make sure cleanup is quick and easy. First, remove all furniture from the room. Then apply and tape down a layer of painter’s paper or butcher’s paper. Lay a painter’s tarp over the paper. Finally, tape and paper off the top 8-12 inches of the walls.
Remove the Current Texture
Some may want a smoother surface to apply paint to. If you scrape the larger pieces of texture off the ceiling, you should be able to maintain the basic pattern. Use a standard paint rolling system to obtain full coverage.
Apply Over Texture
If you don’t want to smooth out the better part of the current texturing, the ideal application tool is going to be an airless sprayer, similar to a Wagner Powerpainter. Your next option is to roll the paint on, but you’ll have to keep the paint thick on the roller to make sure all of the texture receives paint, even in the valleys and crannies.
