How to Paint a Tin Roof
16-24 hours
Beginner
- 400-2,000
Having a plain tin roof is not very appealing to homeowners; there is no color to it and when you wish to paint your home, a tin roof that is not painted will not fit in with the rest of the decor. The same thing applies if you have a tin roof that is already painted and it needs a new coat of paint, or you wish to change the color.
Step 1 - Clear the Surface of Debris
Going right for the gusto and painting the tin roof will leave you with a finished product that simply does not look good. In order to get the best possible result, the roof first needs to be cleaned. Set your ladder up in a central location where you can reach the majority of the surface without having to move too much. Use a push broom to remove leaves, twigs, and larger debris. Then, follow up with using the power washer to remove any dirt and grime that is stuck. This will also take care of any oil and grime that has accumulated over the years.
Step 2 - Prepare the Metal
Removing dirt, oil, and debris is just one part of a two-part process to prepare a tin roof for painting. One issue that tin roofs have, especially older ones, is that they can get worn out and rusty rather quickly. Rust will also be the death of an otherwise great paint job.
First, use the wire brush to remove the loose rust. It should not take much time or elbow grease to knock down the deposits to that the area is flat. Next, use an electric sander with coarse-grit sandpaper to go over the rusted areas that have been knocked down. Use medium pressure on the sander while moving it in a circular motion. It is doubtful that you will remove all of the rust but as long as it is flush with the roof, the painting will be a success. This method should also be used to remove old chipping or peeling paint.
Step 3 - Paint
You need to use paint that is both for metal and for outdoor use as it will usually contain a metal protector. Apply the first coat using a paint sprayer in slow, even passes for the entire length of the roof. Carefully overlap the layer you applied previously until the tin roof is fully painted.
You may not be able to cover the entire tin roof with the sprayer. Rectify this by hand painting. Pour some of the paint into a tray and use various paintbrushes and a paint roller to get to the tough areas. Wait for the paint to dry before adding a second coat if you need to.
