How to Paint Ceiling Trim
Safety glasses
Mask
Trim paint
Tack cloth
220-grit sand paper
Drop cloths
Painters tape
Sash brushes
Stepladder
Painting the ceiling trim can accentuate the walls and ceilings, and it's not that hard to do. Home-improvement stores offer a wide variety of paints and colors to suit your preferences. Here's how to apply the paint once you pick one.
Step 1—Prepare the Area
Cover the area under the ceiling trim with drop cloths to protect it from dripping paint. Move your furniture to another room. Also, make sure the workspace is properly ventilated.
Step 2—Lay Tape
Use 2-inch painter's tape to protect the part of the wall just below the trim. Make sure the tape is adjacent to the trim but not covering it.
Step 3—Sand the Trim
After the painter's tape is down, sand the trim with 220-grit sandpaper. Sanding creates a smooth surface for the new paint. Wear your safety glasses and mask to keep dust out of your eyes and lungs.
Step 4—Clean Up
Use a tack cloth to cleaned off any remaining dust and dirt. There's no sense in ruining new paint by applying it to a dirty surface.
Step 5—Apply the First Coat
The first coat of paint can now be applied to the ceiling trim. Use a small brush to give yourself the necessary control to paint such a tight space.
Step 6—Apply Additional Coats
Let the paint dry completely before applying the second coat. It should take 2–3 hours. Continue this process until you're satisfied with the look of the new paint, but remember to let it dry completely before each new coat.
Step 7—Let It Cure
Once you've applied the final coat of paint to the trim, allow it to cure for a day. After that, just peel off the painter’s tape and put the furniture back in place.
