How to Paint Chipboard
up-close grain of raw, unpainted chipboard
  • 5-10 hours
  • 100-500
Newspaper or large cloth
Medium-grit sandpaper
Large dry cloth
Primer
Acrylic paint
Clear-coat paint
Three painting rollers
Rubber gloves
Large dry cloth
Primer
Acrylic paint
Clear-coat paint
Rubber gloves
Chipboard is a cost-effective material that can be used to produce different goods, like furniture, decorative chipboard boxes, or cabinetry. Though cost-effective, this board is difficult to paint. Follow the rules provided below to paint chipboard correctly.
Step 1 – Prepare the Surface
First, prepare the painting area by laying down large sheets of newspaper or a large cloth. Then, inspect your chipboard to make sure it’s clean. If there is any grease or moisture on the board, the paint won’t stick to it. To prevent getting anything on the chipboard, consider wearing rubber gloves when you handle the board.
Step 2 – Sand the Board
Next, use a piece of medium-grit sandpaper to gently sand the entire chipboard. Sanding the board before you paint it will allow the paint to stick to the board more easily and remove any surface imperfections. Sand the board until it feels smooth. Then, use a dry cloth to wipe down the surface to remove any leftover board debris.
Grab some medium-grit sandpaper on Amazon
Step 3 – Apply Primer
Warning: When using primer or paint, wear protective gloves to avoid skin contact with the substance, and use only in a well-ventilated area.
Primer not only works as a protective barrier, but also it helps to seal chipboard’s porous surface to create a smooth painting surface. Using a roller, apply the primer thinly and evenly. Allow it to dry before adding another coat. Applying multiple thin coats will help the primer layers seal into each other, creating a stronger barrier.
Order all-purpose primer
Step 4 – Apply Paint
Use a roller to apply the first layer of acrylic paint. Do not use paints with a heavy water or oil base, as these types of paint will soak right into the chipboard’s porous surface and make the board look uneven and clumpy.
Apply the acrylic paint evenly with the roller. Allow the coat to completely dry, and then add another 2-3 layers of paint until you achieve sufficient coverage. Add more coats depending on the depth of color you want.
Order chipboard-friendly acrylic paint
Step 5 – Add Clear Sealant
Finally, seal your paint with a coat of clear sealant. Clear sealant will protect your paint job and give it a professional, glossy look. Apply the clear coat with another clean roller, and allow it to dry. Add a second coat, and allow that to dry, too, before you move the chipboard to another location or use it for another project.
Order acrylic paint sealer
