How to Paint Tin Ceiling Panels
Roller with texture ceiling nap
Roller handle and extension
Paint tray
Primer
Ceiling paint
Drop cloths
If you don’t like the look of bare tin, or it just doesn’t fit in with your room’s décor, you can do something about it. It’s not much harder to paint than any other surface.
Step 1—Prepare the Area
Remove as much furniture as possible from the room to avoid splattering it with paint. Cover the floor and any pieces of furniture that are too heavy or cumbersome to move with drop cloths. Remove the curtains and draperies. Painting a ceiling can be messy.
Step 2—Prime the Ceiling
You can’t skip the priming step. The paint will peel otherwise. An oil-based primer is recommended for metal. Pour a bit of this into a paint tray and roll a paint roller through it. Start at one end of the room and work your way across. When you’re done priming, let it dry.
Step 3—Paint the Ceiling
To paint your tin ceiling, simply repeat the steps above using paint instead of primer. Cover all of the embossed areas of the panels using a thick roller cover designed for a textured area.
