How to Preserve Mahogany Wood Floors
A floor made from mahogany wood is one of the best choices you can make for your home. Mahogany is one of the most popular hardwoods in construction. It produces attractive and resilient floors that can earn you the admiration of your guests. The wood has a beautiful pink hue that changes with time to caramel. A mahogany floor also has the natural appeal of wood, which enhances the appearance of your home. The floors are amongst the higher priced types on the market. You want to make certain that yours lasts in good condition for as long as possible. The key is to clean your floor regularly and polish it periodically. Below are steps that show you how to preserve your mahogany floor.
Materials Needed
- Vacuum
- White vinegar
- Warm water
- Bucket
- Mop
- Soft cloths
- Buffer
- 100-grit screen
- Lamb’s wool applicator
- Hardwood floor polish
Step 1 – Remove Dust
Daily removal of dust helps retain the luster of your wood floor. Use a vacuum with soft brush attachment to clear dust from your floor.
Step 2 – Wet Mop
When you clean your floor regularly, it helps prevent color fade and wood rot. Add equal portions of vinegar and warm water in a bucket. Mix the solution well. Dip your mop into the solution and wring it so that it feels damp. Mop the floor in small sections. Use a soft cloth to wipe away excess moisture from the floor. It is best not to leave water on the floor, as it creates water spots. It may also cause the wood to warp. Once the cleaning solution becomes dirty, pour it away and make a fresh solution. Allow the floor 1 to 2 hours to dry.
Step 3 – Buff the Floor
This helps the polish to adhere more effectively. The finish will also not peel off as quickly. You can rent a buffer from a home improvement store. Use a 100-grit screen to buff.
Step 4 – Polishing
Be sure to obtain a wooden floor polish that is suitable for mahogany wood. It is a good idea to apply the polish onto a small area first and observe the outcome. This helps to limit the damage that can be caused when wrong products are used. Use a soft lint-free cloth to apply polish onto the floor. Work in small sections at a time. Rub the polish in well to facilitate more effective penetration. Follow with a second coat of polish. It is best to apply polish once a year.
Step 5 – Buff Again
Use your buffer to give the floor a good shine.
Step 6 - Other Measures
It is best to limit direct sunlight on your mahogany floor. This helps to retain the color qualities of the wood. You may want to invest in window tint for your home to control infiltration of direct sunlight indoors. Be careful when you move furniture and other items across your floor. Ask somebody to help you lift the objects rather than drag them across the floor. It helps prevent scratches and marks on the floor.
