How to Prevent a Car's Fuel Lines From Freezing
When outdoor temperatures dip below freezing levels and water vapor gets into your car's fuel lines, your fuel lines can easily freeze. Fixing a frozen line is typically inexpensive, but it can be frustrating to deal with. Instead, follow these simple steps to prevent the issue from happening in the first place.
Step 1 – Maintaining Your Fuel System
Next, prevent your fuel lines from freezing by pouring a fuel additive into the system. Purchase a fuel-line antifreeze at your local automotive shop to add to your car’s system. Follow the manufacturer's instructions. This substance will keep your lines from freezing over, even at low temperatures.
Step 2 – Keeping the Fuel Tank at Maximum Capacity
In addition, Keep your fuel tank at its maximum capacity to decrease moisture in your system. The less moisture in the system, the less chance your fuel lines will freeze.
