How to Rebuild a Dirt Bike Engine
2-15 hours
Intermediate
- 30-200
Rebuilding a dirt bike engine can be beneficial if it's not working properly or isn't as efficient as it used to be. Rebuilding a dirt bike engine isn't actually that complicated although it can be confusing if you don't have the service manual available for the engine. If it's the first time that you've been doing any engine rebuilding then you need to be careful that it's done properly, otherwise you can cause irreparable damage to the engine. Follow these few simple steps and you shouldn't have any issue rebuilding and improving the quality of your dirt bike engine.
Step 1 - Dismantling the Engine
First you need to set to work taking the engine apart. To do this, first take the spark plugs out of the engine and disconnect the carburetor.
It will also be easier to work on the engine once it is taken off the bike, undo the mounting screws on the engine and pull the engine away from the dirt bike frame. Set it down somewhere level and easily accessible. If the engine only requires partial rebuild or changing of the piston rings then this can be done at this stage without the need of dismantling the entire engine.
Step 2 - Dismantling the Top Engine
Remove the bolts at the top end of the engine to disassemble the top end of the dirt bike engine. Once this is removed you will be able to slowly pull the top end away from the piston. At this point the piston can be removed for re-boring or replaced with a new cylinder.
When every part of the engine is removed you should inspect it for signs of wear and tear. If there is any damage then you will need to consider replacing these. Clean them in warm soapy water to ensure that they are free from all debris and then set them aside. If any components need replacing then ensure that they are replaced using the right components and are of the best quality.
Step 3 - Reassembling the Engine
Start rebuilding the engine by first replacing the cylinder and oil seals with new ones. The air filter should also be replaced. Once the engine is rebuilt you can then secure the spark plugs into the engine. Ensure that these are as tight as possible, if there are any loose spark plugs then they can prevent the engine from firing correctly even if the rest of the project is successful.
Step 4 - Testing the Engine
Turn the engine on and check that everything works properly. Run the engine at half power for a few minutes; after this time the oil should be changed. By removing the oil and replacing it with new oil you will be able to prevent any damage caused to your engine by loose bits of metal.
