How to Reduce Damage When Drilling Through Mosaic Tile
Lead Image for How to Reduce Damage When Drilling Through Mosaic Tile
  • 1 hours
  • 0-20
Masking tape
Drill
Tile drill bit
Spray bottle
Water
Masking tape
Drill
Tile drill bit
Spray bottle
Water
Mosaic tile is a beautiful style. The tiles are arranged in intricate patterns; a time may come when you need to drill a hole through the mosaic tile. To reduce the damage done to the mosaic tile, follow these steps.
Mark the Spot
Determine where on the mosaic tile you want to drill the hole. Place 2 pieces of masking tape where you want to drill the hole. Form the tape in and "X" with the center of the "X" marking the spot for the hole.
Prepare the Drill
Install the tile drill bit and spray it down with cold water. Place the drill over the tape and hold the drill as level as possible.
Drill the Hole
Mosaic tile is very touchy. When you drill the hole, make sure that the drill bit is level. Use even pressure while spraying the bit with water.
