How to Reface Bifold Closet Doors
Bifold closet doors offer access to your closet without taking up much space. These doors easily fold back so you can see everything you have without having to slide or open doors into the room. With a little bit of paint and decoration, you can turn your bland bifold into a grand doors.
Step 1. Wash and Clean
Lay down the doors on the tarp. Remove any knobs or screws, and fix any damage with molding or adhesive. Use sand paper to level any uneven surfaces
Use some gentle soap and water to wash the doors to remove any smudges and dirt. Let the surface dry.
Step 2. Paint Panel
Decide which color would look best on your door. Usually, an accent color with two brighter shades look good. One will be for the trimming and the other might be a shade or two darker for the inner panels. You can use colors that are very far apart on the color wheel or colors that are very close together.
Paint the top, bottom and side boards, and let them dry. Paint the trim as well. Tape the inside of the door once they are dry, and begin to paint the darker shade of color on the inside panels. Let the paint dry before you turn over to do the other side.
Step 3. Paint Flat Door
Paint the door in the direction of the wood grain, usually from the bottom to the top. For a finished look, make sure your brush trails off the edges of the door to recreate a finished look. Let this side dry before you paint on the opposite side. You may want to add another coat of paint when you have finished painting on both sides of the door.
Step 4. Fabric
When the paint has dried, you have the option of hanging a unique design of fabric onto your door. Use spray adhesive to attach the fabric.
Step 5. Door Knobs and Handles
Look around for objects and material that might inspire you to find the same style or pattern for a doorknob. Look for color and shapes that can be matched in finding the right door knob that fits your closet. If you have Victorian style of room, consider ornate or jeweled designs. If you are in a child's room, consider finding a handle that has animals and flower shaped designs.
Step 6. Finishing Touches
You can use self-stick mirrors on to your bifolds to give the illusion of more room and space. Also you can use a hammer and nail to facet 1 or 2 hangers onto your door to add your own pictures and painting that you like.
