How to Remove a Car Gearbox
Floor jack
Jack stands
Transmission jack
Socket set
Wrench set
Breaker bar
Phillips screwdriver
Flat blade screwdriver
Needle nose pliers
Masking tape
Ballpoint pen
If you are having problems with your vehicle's transmission, you may have to remove the car gearbox in order to correct the situation. So, you will need to know how to properly remove the transmission (gearbox) in order to make needed repairs. This simple how-to guide will show you everything you need to know.
Step 1 - Prepare the Vehicle
Find a flat, dry place to work, and then remove the negative battery cable from the terminal post on the battery.
Step 2 - Remove the Gear Shifter Handle or Knob
Twist the gear shifter handle or knob counterclockwise until it comes off.
Step 3 - Remove Trim Plate or Console
Some vehicles come equipped with a shifter trim plate or console. If your car has either one, you'll need to remove it before you can proceed.
Step 4 - Jack Up the Vehicle
Using the floor jack, jack up your vehicle and place it securely on jack stands.
Step 5 - Remove Cables and Wiring
You'll need to remove the speedometer cable as well as any electrical wire harnesses or other wires that may be attached to car's gearbox. When removing these items, always label them with masking tape and a ballpoint pen, so that you'll know what they are when you re-install the transmission.
Step 6 - Remove Transfer Case
Remove driveshaft (rear wheel drive) or axle shafts (front wheel drive). If your vehicle has four-wheel-drive, you will need to remove the transfer case by loosening the bolts that attach it to the transmission.
Step 7 - Remove Shifter or Shift Levers
If your vehicle comes equipped with shifters or shift levers that are attached to the transmission, remove the nuts and bolts that hold them in place, and the shifter or lever and put it in a safe place.
Step 8 - Remove Transmission Mount
Remove the bolts that hold the main transmission mount in place, and then remove the mount and set it aside.
Step 9 - Remove the Crossmember
There will usually be four bolts that hold the crossmember securely to the frame. Remove them and then remove the crossmember.
Step 10 - Place Jack Under Transmission
Before you can actually remove the transmission in your vehicle, you'll need to place the transmission jack directly under the transmission. A regular floor jack will not usually provide lateral support for your car's transmission, so don't attempt to use it for that purpose.
Step 11 - Remove the Gearbox
Only when the transmission jack is in place, can you begin removing the gearbox itself. Locate the bolts that hold the transmission in place and then use a breaker bar to loosen them slightly. Then, adjust your transmission jack so that it is touching the bottom of the transmission, and then finish removing the bolts. Don't attempt to remove the bolts unless the transmission jack is placed in contact with the transmission as it may fall and cause damage to the transmission or injury to you.
