How to Remove Concrete Countertops for Kitchen Remodel
  • 2 hours
  • 0-50
Screwdriver
Pliers
Wrench
Cardboard
Utility knife
When removing concrete countertops, in a kitchen, you will have to be careful not to damage the cabinets under it unless you plan to replace them as well. How you remove a concrete countertop also depends on the type of base and joints underneath. If the countertop is secured with screws and bearers, it will be easy to remove. The following is the procedure to remove a concrete countertop that is secured with screws and bearers.
Step 1 – Remove Items from the Floor Cupboard
Take out all the things, cups, plates, pots, food cans, glasses, spoons out of the cupboard and place them in a pantry or in another cupboard.
Step 2 – Take out the Sink
Take out the sink. Remove the screws under the lips at the bottom of the sink including any sealing compounds between the joints. This should loosen up the sink. Remove the built-in stovetop if there is one. Remove the screws from the bearers and gently lift out the stovetop. You must also remove any fixtures that are attached to the countertop. Remove drawers from the floor cupboard and put them aside.
Step 3 – Trace the Holes
With a large piece of cardboard that you place over the sink opening, make a template tracing the shape of the opening using a marker. Cut out the shape of the opening and you have yourself a template if you want to re-use the same sink and fittings in your kitchen remodeling project.
Step 4 – Remove the Screws
Light up the room and open the floor cupboard doors. Locate the screws or bolts and nuts under the countertop. Remove the screws along with the bearers at the corners and at the top rails running along the internal perimeter of the cupboard. Take out the screws around the sinkhole and above the drawer slots. If the concrete top is held by bolts and nuts, use pliers to unscrew the nuts.
Step 5 – Remove the Caulk
Take a knife and scrape away the sealing compounds between the joints where the concrete slab and cupboard meet. Cut out the silicone, putty, acrylic, or beads along the joints. Remove the sealing compounds where the countertop meets the wall.
Step 6 – Lift out The Concrete Top
Get a team of four people to lift out the concrete top. Each person must hold the concrete top at the corner. Firmly hold the concrete top and place it outside the house, in a garage or back yard.
