How to Remove Makeup Stains from Faux Leather Jackets
Clean cloth
Paper towel
New, soft sponge
Water
Mild soap
Bucket
Stiff bristled brush
Cornmeal
When it comes to your faux leather jackets, the last thing that you want to deal with is a makeup stain. Here are a few steps that can help you remove it easily.
Step 1 - Clean off Excess Makeup
First, clean off any of the excess make up that has yet to stain. Use a paper towel to blot or grab any makeup without rubbing it further into the leather.
Step 2 - Remove Makeup
In a bucket, mix a small amount of mild soap with warm water and dilute it. Then use a sponge with the solution to gently wipe off the makeup stain from the faux leather jacket. Then, use a dry and clean cloth to dry the area.
Step 3 - Use Cornmeal
If the damp sponge did not work you can try using cornmeal on the area. You will need to apply it to the area, allow it to sit and then use a soft bristled brush to brush off. This should help to remove the stain and then you can clean the area off completely with a warm damp rag.
These steps should help you in the removal of any makeup stain, especially liquid foundation.
