How to Repair a Fiberglass Shower Floor
Acetone
Clean cloth
Damp cloth
Dye grinder
Dye cone
Protective mask
Protective glasses
Rubber gloves
Fiberglass catalyst
Fine grit sand paper
Vacuum cleaner
Car polish
Felt roller
Gel coat and toner
Electric buffer
Fiberglass shower floors are very durable and can last years with very little maintenance; however, if your fiberglass shower floor is struck hard enough by a hard object, it will crack. Fiberglass is made of reinforced plastic resin and is used in various construction projects including shower stalls and shower floor constructions. You can easily repair a cracked or fractured fiberglass shower floor by using fiberglass filler. Below are the materials that you need along with the instructions on how to repair a fiberglass shower floor.
Step 1 - Clean the Cracked Surface
Clean the fractured surface with a damp cloth dabbed in acetone. Doing so will remove contaminants that will hamper your repair and prepare your fiberglass floor for the next step.
Step 2 - Remove the Damaged Fiberglass
With a grinding cone attached to a dye grinder, grind the damaged fiberglass. Do not grind through the fiberglass floor. Your aim is to remove the cracked fiberglass only. At this time you should be wearing your protective glasses and protective mask.
Step 3 - Clean the Working Area
Clean the area with clean rag dabbed in acetone. Allow the acetone to completely dry before proceeding to the next step.
Step 4 - Prepare the Fiberglass Filler
With rubber gloves on, prepare enough fiberglass filler for your repair project. Gently pour the fiberglass catalyst into the fiberglass and mix thoroughly until the fiberglass filler is consistent in color.
Step 5 - Apply the Fiberglass Filler
Use a putty knife to fill the damaged area of your fiberglass floor with the filler. Ensure that the fiberglass filler is level with the floor surface of your shower. Allow the fiberglass filler to dry overnight.
Step 6 - Use Sandpaper
Once the fiberglass filler is completely dry, use fine grit sandpaper to smooth the surface. Remove debris and fiberglass dust with a vacuum cleaner. Apply acetone using a clean rag on the newly patched areas again. Allow the acetone to completely dry before proceeding to the next step.
Step 7 - Apply Gel Coat
Prepare the mixture of gel coat and toner in a small bucket. Add catalyst and stir the solution thoroughly until it is uniform in color. Use a felt roller to apply the gel coat on the areas where you applied the fiberglass fillers. Allow the gel coat to harden. Smooth the area with fine grit sand paper. Rinse the area with water to remove dusts and debris.
Step 8 - Finishing Touches
With a clean rag, apply a single coat of car polish on the working area. Allow the car polish to completely dry before buffing the area with an electric buffer. You have just learned how to repair your damaged fiberglass shower floor.
