How to Repair Rocking Chair Rockers
A rocking chair.
  • 1-2 hours
  • 25-40
Glue
Wood clamp
Wax paper
Drill machine
Hammer
Saw
Rod
Glue
Wood clamp
Wax paper
Drill machine
Hammer
Saw
Rod
If the rocker of your rocking chair is broken, it is quite obvious that the rocking chair will not rock. Fixing the rocking chair is a simple task, provided you follow the steps mentioned below.
Step 1 - Glue
Apply glue to both the rocker pieces together and make sure to select a strong wood glue.
Step 2 - Clamping
Get hold of the wood clamp and install it, to ensure that the two pieces are stuck to one another. You can use the wax paper to make sure that the clamp is supporting and does not stick to the wood.
Step 3 - Reinforcement
Reinforce the break. You would require a drill machine and drill a hole right inside the rocker, through the break. Then take some glue and spread it inside the hole. With the help of a dowel, hammer it right in the hole. Let the chair to dry overnight.
Step 4 - Excess Dowel
Utilize a saw and remove the excess dowel inside the hole, once the glue is dry. Then cut the dowel off, so that it is flush with the rocker, smoothing it out with sandpaper.
