How to Repair Solid Surface Bathroom Countertops
Solid surface adhesive
Putty knife
Masking tape
Sealer
Razor blade
Soft cloth
Solid surface bathroom countertops are durable, and they come in a variety of materials and colors. These countertops are also very easy to clean. They are also water resistant. On the flip side, the solid surface countertops are susceptible to scratches and to discoloration. Fortunately, solid surface bathroom countertops are inexpensive to repair; just follow these steps.
Step 1 - Clean the Counter Top
Remove everything and apply solid surface cleaner with a soft cloth to clean the bathroom countertop. Dry the surface with a lint free towel.
Step 2 - Mark the Area
Mark the damaged area with several layers of masking tape. Extend the masking tape 1-inch outside the scratched surface.
Step 3 - Apply the Adhesive
Use an adhesive that is made with a 2-part epoxy. If you have a standard color solid surface, you may be able to find an adhesive that is the same color as your solid surface countertop
Follow the manufacturer's instructions to apply the adhesive. Wipe away any excess with a razor blade. Work gently to avoid scratch the surface even more. Allow the adhesive to for at least 24 hours.
Step 4 - Apply Sealant
Apply sealant to the countertop according to the manufacturer's instructions. The sealant will maintain the brilliance of the countertop and protect against scratches and chips.
Step 5 - Wipe Clean
Wipe the countertop clean with a mild soap and water or with a solid surface cleaner once the sealant has been allowed 24 hours to dry.
