How to Replace Piston Rings
Wrenches
Sockets
Torque wrench
Towel/rags
Scraper
Kerosene
Piston ring tool
Piston rings
It’s important to have piston rings that fit well in order for your car to perform properly. Replacing piston rings is a big job and most people will take their vehicle to a garage to have the work done. However, you can still do it yourself. You only need some basic tools and a little time, along with the service manual for your vehicle.
Step 1 - Access the Piston Rings
In order to get to the piston rings, you’re going to have to remove the cylinder head. This is an involved process, as you’ll need to disconnect many things before you can even remove the part itself. Start by draining coolant, then removing the exhaust manifold. Loosen the bolts holding it to the head with your wrench, and pull it away. Then, you'll need to disconnect the distributor from the intake manifold. There will be spark plug wires attached to it, so pull these out of place before you undo the nut holding the distributor on top of the intake manifold. Unbolt both the valve corners and the intake manifold itself.
The rocker arms and pushrods are your last obstacle before you get to take care of the head itself. Fortunately, all you need to do is remove the single nut on top of each rocker arm in order to pull it away; there will be one rocker arm and pushrod per valve. Once the rocker arms are lift away, you can pull the pushrods up through the head.
There’s a procedure for removing the cylinder head's retaining bolts, beginning with the bolts on the outside. When this is finally off, you’ll need to start cleaning the top of each cylinder. Make sure that there is no grease or dirt present so you'll be prepared to replace the cylinder head when you're finished.
Step 2 - Clean
Before you can replace the piston rings, it’s important to fully clean the piston. Cover all the cylinder holes to prevent debris from the piston from falling inside. Then, simply scrape off the dirt until enough is removed that you can pull out the piston.
Step 3 - Remove Piston Rings
Before you can change the piston rings, you’ll need to remove each of the pistons. This will vary from make to make, so you’ll need to consult your service manual. When you’ve removed the pistons, they will also need to be cleaned. Do this by soaking them in kerosene before allowing them to dry completely. Do this in a well-ventilated area.
You’ll need to use your piston ring tool to remove the old piston rings. Before replacing them, check each of the ring grooves on the piston for wear by using a feeler gauge to see if they still meet the proper specifications. If the grooves have worn too much, replacing the piston rings won’t be enough; you’ll need a complete new piston. If the rings don’t want to move, you can loosen them by soaking them overnight in kerosene.
Step 4 - Install New Piston Rings
When you’re ready to put on the replacements, you need to stretch them with your piston ring tool as you fit them over the piston. However, you need to be very careful that you don’t stretch them so much that they break (if they do, new piston rings are very cheap).
Make sure that the piston rings are secure in the ring grooves. When you’ve done that, inspect the piston once more before replacing it along with the connecting rods. New bearings should be used on the connecting rods. Reverse the process you used to remove them. Then, before replacing the cylinder head, check the head gasket. In most instances, you should replace it while working on the piston rings.
Finally, put on the cylinder head and reattach all the other items to the engine block to finish.
