How to Replace the Bath Tile Grout
4 hours
Beginner
- 50
Bath tile takes a lot of abuse over the years. It gets pummeled with water, soap, and other chemicals. All of this abuse causes the grout to become moldy and worn out. When grout becomes worn, it dries and cracks. When the grout is damaged, it needs to be replaced. It is not a fun job, but it is not difficult either. The biggest problem associated with replacing grout between bath tiles is how long it takes. It is tedious, but the following article will show you how to do it properly.
Step 1 - Cut the Grout
Removing grout between bath tiles is a process that is both time-consuming and delicate. In the past, you would use a small chisel and hammer to break the grout; however, this method can damage the tiles. A grout saw is the best choice, although an oscillating tool or a reciprocating saw equipped with a grout removal blade works wonders for any type of grout. Carefully cut the grout as close to the edge of the bath tiles as possible. Repeat the process for the other side of the tile. The oscillation of the grout saw will remove the grout. Use your shop vac to pick up the debris and dust.
Step 2 - Clean the Edges
No matter how well you work the grout saw, you will always be left with grout sticking to the side of bath tiles. In order to replace the grout, you will need to remove the excess. Slide the wire brush or the grout hand saw between the spaces and begin rubbing along the edges. This should effectively remove the grout that is still sticking to the bath tiles. Use the vacuum to suck up the dust particles, then inspect the grooves. Repeat the process until the sides of the bath tiles are clean.
Step 3 - Wash Down
Next, clean the bath tiles with a damp sponge. Let the tiles dry on their own. Removing dust and other particles is important to maintaining a clean grout that bonds correctly.
Step 4 - Grout the Bath Tiles
Applying grout is relatively simple. Mix the material according to the directions if you are not using ready-made grout. Use the grout float to scoop the grout and slap it over the bath tiles. Smooth the grout over the tiles. Use firm, even pressure to press the grout inside the spaces between the tiles. Use a damp sponge to wipe down the bath tiles. Doing so removes the grout haze that may form over the tiles. Use as much grout as needed and wait several days for the grout to dry completely.
