How to Reset a Garage Door Opener Keypad
Lead Image for How to Reset a Garage Door Opener Keypad
Getting locked out of the garage is one of life's most frustrating experiences. When you need to know how to reset a garage door opener keypad, you need to know how to get it done quickly and easily so you can regain control.
Everyone who has a garage needs to know how to reset a garage door opener keypad, because you will have to change this code at some point. Once you learn this process, you won't have to be locked out of the garage ever again.
Opening the Garage Door
Most garage door openers enable you to access your garage by means of a separate keypad. The garage door keypad is located outside the garage door and can be activated and deactivated by providing your specific personal identification number, or PIN.
So if you don't know that PIN, you've got problems. You might find that you can't even get the garage door open.
That can be a pretty serious problem. After all, you can’t use the garage if you can’t even open the door!
You need to know how to reprogram garage door opener keycodes. There are a few different ways to do this but all of them are fairly simple.
Resetting Your Garage Door Opener Keypad
It's like one of those tests in life when you find that you can't get the garage door open. It's one of those moments where you really find out how much patience you have.
And if you haven't got much, that's okay. There are a few fairly quick and simple ways you can figure out how to reset garage door opener keypads to get things back on track and get yourself right back in gear.
You might need to try a couple of different methods, depending on the type of door you have, so hold onto that patience while you run through some options.
Check
Give the garage door and the motor unit controlling it a careful look. Visually check to make sure that no part of the door or the mechanism is being blocked by anything and that nothing is in the way of opening the door.
It's likely that the motor for the garage is in the ceiling of the garage. You might need to use a ladder to get a closer look at the mechanism to perform a strong visual inspection.
Even a small piece of debris could prevent the system from working, so clean away any foreign objects that you see and re-test the door once this is done.
You may not always need to access this part of the garage door when it comes to learning how to reprogram garage door opener key codes, but it’s most likely that you will. This means you need to get out the ladder and get prepared to access this motor instead of skipping this step.
Enter Learn Mode
If you want to re-key your garage door, you will need to access the “learn” mode. In most garage door designs, there are two different ways to do this.
Look for the learn knob on the motor, which is usually under the light cover or on the side of the mechanism. In many newer garage doors, you can access the learn mode using your phone because the garage door controls are accessible through WiFi.
Erase the Code
You have to get rid of the existing code in order to program a new one. Reset the memory by holding down the learn button or using the function in the learn menu on your smartphone or wireless device.
When the light turns off or the smartphone lets you know, the memory has been wiped and you can now program a new code. Now, you’re ready for the rest of the process of learning how to change garage code PINs.
Program a New Code
Press the button to enter a new code. When the LED indicator turns on, release the button.
You usually have only about 30 seconds to enter your new PIN code, so have that all picked out and enter it precisely when the mechanism is ready. You might need to hit or hold down the enter button to get the PIN to save.
When the LED light blinks on the garage opener, you have programmed the PIN the right way. Test it out in the new door a couple of times.
This is probably the most common method to use when you need to learn how to reset garage door opener keypad codes. However, there are other ways it might need to be changed depending on the manufacturer that made the door.
If you can't figure out how to change garage code PINs, don't fret. Some companies might require you to hit special symbols when you're setting a code and the process isn't always as straightforward as it should be.
If you have any trouble, look up the make and model of the garage door online and you will be able to find instructions for resetting the key code.
Program a New Code Without a Keypad
Not all garage door openers have a keypad ad that's really when your patience is going to be tested. However, it is possible to reset your garage door opener even without this feature.
Open the cover on the remote and press the programming button. Hold it down and a red light should turn on or start blinking.
You might need to use a screwdriver to loosen screws and remove the cover, depending on how it's designed. Be sure to place these screws somewhere you won't lose them or forget them.
You will see switches that can be moved and flipped so they are facing in different directions. This is how you can change the code.
The switches here will match the positions of similar switches inside the garage door opener mechanism. Flip the switches to the way you want them and then carefully remove the cover on the motor of the garage door opening to access the switches here.
Position the switches so they mirror each other across both the door mechanism and the remote. This is how you reset your garage door code without a keypad.
Garage Door Security
It is important to know how how to change garage code PINs to prevent unwanted entry into your garage. You might need to change this code because someone else knows it, because there is an increase in crime in the area, because it's been a while since you changed it, or because it's been forgotten or lost.
No matter why you're changing it, choose a new code with security in mind. Do not use your birth date or the date of your wedding anniversary or any other digits associated with your personal information.
Under no circumstances should you use the house number where the garage is located or the last four digits of your own Social Security number or phone number. Choose a number that you can easily remember that even those close to you might not connect to you for any reason.
Don’t use anyone’s birthday or anniversary, as these numbers are generally too easy to guess.
What were the numbers of your childhood home, or the birthdate of your favorite pet? Think of numbers like these that you can remember and know but that are so personal or so obscure, no one else would guess them if they are trying to crack the code.
Fixing the Garage Door Opener Keypad
If your garage door is acting up and that's why you changed the code, it's possible the code isn't even the problem. It's possible that some part of the garage door or remote may need to be repaired.
If your garage door opener's keypad isn't working, there are a few things you can do to troubleshoot it.
You should start by checking for frayed wires. You can open the control and look for frayed wiring between the keys.
If you see any, remove the batteries from the device to make sure the power is off. Detach the wires, replace them, and attach the new ones.
Stuck keys could also be the culprit if the keypad isn't working properly. This is usually caused by dust and grime seeping into the keypad around the keys and can be fixed by cleaning the unit.
Get a can of air and use it all around and all over the keypad and see if this improves the issue.
Reset Garage Door Opener Keypad
Once you know how how to reset garage door opener codes, you won't have too much trouble or spend a lot of time on learning how to change yours. It's a good idea to change this code every once in a while for the sake of security, so it's always worth it to learn how to do this.
It can be an incredibly frustrating experience to be unable to open the garage door easily. After all, the whole thing is supposed to be designed for ease and now, you're on the wrong side of things.
Don't lose patience. You can reprogram the door in just a few minutes, even if you have to try a couple of different methods to do to it.
Follow the process to reprogram the door and soon, you'll be back inside your garage easily.
Garage Door Opener Keypad FAQs
How do I reset my garage door opener keypad?
Though there are a few different ways it can be done, learning how to reset garage door opener keypad codes means that you will essentially need to wipe the memory and program a new pin code. This might require flipping switches or pushing buttons or using a smartphone, but you will be resetting the code so you can fully and easily gain access to your garage again.
How do I reset my garage door keypad without a code?
If you don't know the code to the garage door, you will need to know how to reset garage door code numbers. There are a few different ways this can be done depending on the garage door manufacturer but essentially, you will wipe the memory of the device and reprogram a new keycode.
Why is my garage door opener not responding to keypad?
If the keypad is not responding to the code you're punching in, there could be a number of reasons. You might need to reset the code because actually, you're entering the wrong code.
There could be something not connecting properly in the garage door remote or in the mechanism itself. If resetting the PIN code does not work, you can always try to repair or replace the garage door opener device.
How do I sync my garage door opener to my keypad?
Most of the time, you can change your garage door opener code by pressing a certain button on the device or using your smartphone to access the settings for the door. You might have to take the cover off the opener and off the garage opener mechanism and manually change the code this way.
There are a few different ways to reset garage door keypad without code numbers. Performing a garage door keypad reset is not difficult, especially after you've done it once and you've figured out the particular process for your door.
Resetting garage door keypad numbers might take a couple of tries but once you've done it, you'll get able to get through the whole process pretty quickly.
Further Reading
4 Tips for Ultimate Garage Security
Automatic Garage Door Repair Guide
Can't Close Garage Door with Remote
Choosing the Garage Door Opener Right for You
Garage Door Maintenance: How to Tune up a Garage Door
Garage Door Rollers Off Track: How to Repair
Garage Door Torsion Spring Repair
How to Replace a Garage Door Seal
Pros and Cons of a Roll up Garage Door
Replacing Garage Door Panels: Common Errors to Avoid
Step-By-Step Garage Door Repair
Troubleshooting a Garage That Won’t Close in Cold Weather
What to Do About Lost Garage Door Openers
