How to Size Your Ceiling Fan
Picking out the right ceiling fan is about more than just style. The size of the fan is just as important as looks and contributes to better performance and longevity of the fan, not to mention your own comfort level. By following this simple guide, you can pick out the right size fan for any room of the house and rest assured that you are getting the most out of your investment.
Step 1 - Room Size
The size of the room determines the overall length of each fan blade. To find the square foot of a room, simply multiply length times width. For example, a room that measures 8 feet by 8 feet is 64 square feet in size. If the room is larger than 400 square feet, then two fans should be used for maximum performance.
Step 2 - Blade Size
Blade size is measured two different ways, depending on the number of blades in the fan. For odd numbers, measure from the tip of the blade to the center of the fan. Once you have the correct measurement, multiply the number by two. For even blades, measure the complete distance from one blade tip to an opposing blade. No further calculations are necessary.
Step 3 - Blade Span
With the square footage of the room and blade size figured out, you can now determine the appropriate size of the fan. For rooms less than 75 square feet, the blade size should range from 29 to 36 inches. For rooms that are between 76 and 144 square feet, a fan blade length of 36 to 44 inches is appropriate, while 144 to 225 square foot rooms should utilize a 44 to 54 inch blade. Fan blades that are 50 to 72 inches can be used for large rooms that range between 225 and 400 square feet.
Step 4 - Ceiling Height
Always keep in mind ceiling height when selecting a new fan. The proper distance from the fan to the floor is around eight feet. The fan will not work efficiently if installed any higher or lower than this distance. Thankfully, many fans come with an adjustable mounting option that allows for installation in just about any room. To figure out the correct fan height, simply measure the height of the ceiling and select the right mounting option.
Flush Option
Flush mounts are perfect for rooms that have lower ceilings and do not require a lot of space between the fan unit and the ceiling. Flush options are also great if you desire a low profile fan or do not have a lot of space to work with. These types of mounts are installed directly in contact with the ceiling and do not require an extra attachment to lower the height.
Downrod Option
Downrods are included for rooms that have high ceilings. These rods lower the fan to the appropriate height, which is typically eight feet from the floor. If you need a downrod, make sure you double-check the unit to make sure it is included and is the correct length for the room. Spaces that contain extra tall ceilings may require an even longer downrod than is included in the original packaging.
Installation Tips
Once you have determined the right fan size, there are a few things to keep in mind during installation. For fans that come equipped with a light, make sure there is an available outlet box in the ceiling for the electrical work. Further, ensure that the outlet box is metal as most fans will not work with a plastic box. Call a certified electrician if an outlet box is not available.
Tips and Tricks
Ceiling fans work by moving air throughout the room and can thereby help cool and heat spaces depending on the season. The fan blades should move in a counterclockwise direction in the summer to move cool air down and clockwise in the winter for the opposite effect. If you think size doesn’t matter, a small fan in a large room will have to work hard to circulate air while a large fan in a small room will generate too much wind, not to mention raise the electric bill.
Installing a ceiling fan can be a bit cumbersome if you haven’t done it before. If you need help, The Home Depot offers free workshops on a variety of DIY topics so you can ask questions and learn techniques from an expert.
