How to Test a Chest Freezer Compressor Relay
1 hours
Beginner
- 0-20
Testing your freezer compressor is not difficult and can save you money on a repair visit. If you are up to the task, unplug your freezer and pull it out so that the back is exposed for you to work on.
Step 1 - Remove and Examine
The compressor relay is located at the lower bottom of the freezer, beneath the terminal cover. Pull it off of the compressor and use the needle-nose pliers to pull the connector that connects the wire on the side terminal of the relay.
Step 2 - Test the Relay
Set the multitester to X1 and place the relay upside down. Put the multitester probes into the S and the M terminals. It should read 0 ohms. Keeping the probes plugged in, turn the relay right side up. The magnetic switch should engage and the multitester should read infinity.
Repeat this step on the M and the S terminals individually. If the readings are the same, 0 upside down and infinity right side up, your compressor relay is fine. If this test fails at any point, your compressor relay is faulty and you must replace it with a new one.
