How to Use a Garment Steamer
A purple-and-white handheld garment steamer lying on top of a blue shirt.
  • 1 hours
  • 0-30
Garment steamer
Water
Clothes
Clothes hangers
A garment steamer can be a boon for keeping clothes free of wrinkles. If you choose the right one, it saves all the back breaking work or ironing, and each item of clothing is ready to hang. A garment steamer is easy to use, as long as you do it the correct way. Do it well and your clothes will look perfect when you put them on.
Step 1 - How It Works
A garment steamer is a hand held device. Water is placed in the tank and is heated until it becomes steam. The steam is directed at pressure through a nozzle to the garment. The heat relaxes all the fibers in the garment, which eliminates the wrinkles in the clothing.
Step 2 - Preparation
Put cold water in the water tank of the garment steamer. Check to ensure all the parts are properly connected. Turn the device on and allow the garment steamer to heat until steam forms.
Step 3 - Shirts
Put the shirt on a hanger. You should button the collar and a couple of buttons below it. To make life as easy as possible, hang the shirt from something that will easily let you reach all around it-a shower curtain rail is ideal for this.
Steam from the bottom of the shirt, moving upward. Direct the steam at the material and pay particular attention to the collar area. After you’ve finished, let the shirt hang for a minute before putting it in the closet. This will allow the dampness to air out.
Step 4 - Dresses And Skirts
Dresses and skirts can be made of many different types of fabric, with different printing, so special care is needed with these. Where the material itself is delicate, such as silk or velvet, make sure that the nozzle of the garment steamer never directly touches the material.
Where clothing has been embroidered or screen-printed you should turn the item of clothing inside out and steam that side instead. That way there’s no risk of damaging the print or embroidery, and the wrinkles will still disappear. When you’ve finished, give the clothing a minute for the dampness to fade, turn right side out and hang in the closet.
Step 5 - Heavier Material
Where you’re steaming a heavier material, you might well find that it needs several steamings before all the wrinkles go. As an alternative to this you can also use the garment steamer on the inside and the outside of the piece of clothing.
Step 6 - Water Level
Check the water level in the tank after each item of clothing. This way there will be no danger of the water running low. If you let the water run out you can end up damaging the garment steamer. On the other hand, if you put too much water in the tank, all that will come out will be water, not steam.
Step 7 - Other Uses
A garment steamer is surprisingly versatile. You can also use it on drapes, upholstery and even wigs. Many people pack travel size garment steamers when they go on trips.
