How to Use a Ratchet Screwdriver
A green and black ratchet screwdriver on a white background.
  • 1 hours
  • 0-60
Ratchet screwdriver
Bit set
Screws
Ratchet screwdriver
Bit set
Screws
A ratchet screwdriver is one of the most useful tools you can have in your toolbox. With a good selection of bits, this one device can take the place of an entire screwdriver set and be even easier to use. It isn’t an expensive item either, and one that only takes a couple of minutes to master with the right advice.
Step 1 - Have a Wide Selection of Bits
It’s important to purchase a variety of bits that fit your ratchet screwdriver. You will need flathead types, Phillips head, and square drive bits to ensure you’ll be able to handle any screw you encounter, no matter what. Also, make sure you have a full range of sizes in all styles.
Step 2 - Insert a Bit
Most of your bits will be double-ended, with a different tip on each side. To insert one correctly, grasp it between your thumb and forefinger, and push it firmly into the hole on the blade of the screwdriver until secure. Most ratchet screwdrivers have a magnet holding the tip in place, but some others require you to twist until the driver end is tight around the bit.
Step 3 - Change Your Bit
assortment of bits
To remove a bit from the screwdriver, grab it with your thumb and forefinger and pull sharply. In most cases, it will come right out. When it doesn’t, the usual cause is sweat on your skin causing your fingertips to lose their grip on the metal. Wipe your fingers and the bit with a dry cloth and try again. Then, once it's free, you can choose another to replace it.
Step 4 - Push the Ratchet Tab Down
The beauty of the ratchet screwdriver is the ratchet itself. It means you don’t constantly have to stop and adjust your wrist position as you put a screw into a surface; the handle itself turns instead. Without that extra step, the process is much faster and smoother with less wear on your wrists.
Hold the screw in position and put the tip of the bit into the screw head, making sure you have the correct size. There are three positions for the ratchet tab. To drive in a screw, push the tab down all the way, toward the blade, and start to turn. When your wrist has turned as far as it will go, twist the driver toward you. Only the handle will move back, not the blade. Continue driving the screw all the way home without expending the extra effort.
Step 5 - Pull the Tab up for Removal
To remove a screw, insert your bit into the head just like before, but this time, pull the ratchet driver's tab toward you, moving it all the way. Then, turn the handle counter clockwise. Keep going, utilizing the ratchet motion, until the screw is all the way out.
Step 6 - Use the Middle Setting for a Traditional Driver
using a screwdriver on a screen
As mentioned previously, there are actually three tab settings on this tool, so you're likely wondering by this time what the third does. The middle setting will keep the blade fixed so the device performs like a regular screwdriver. Once you’re used to the way a ratchet screwdriver operates and how easy it is to use, you might never use this setting, but it is still important to know about.
