How to Use a Wall Mount Toilet Brush
Person cleaning a toilet
  • 1 hours
  • 8-20
Toilet Cleaner
Vinegar
Lavender Oil
Toilet Cleaner
Vinegar
Lavender Oil
A wall mount toilet brush is the perfect way to keep your toilet bowl clean while at the same time adding a bit of style to your bathroom. You can find wall mount toilet brushes made of metal, plastic, and ceramic. Just make sure you use it properly so it will last a long time.
Step 1 - Cleaning the Toilet
Spray toilet bowl cleaner around the inner rim of the toilet. Then take your wall mount toilet brush and scrub the toilet bowl, ensuring that the cleaning product is spread around the entire bowl. Don't be afraid to scrub hard where there are water marks or other stains. Follow the instructions of the toilet cleaner so that you know you are cleaning your toilet properly. Make sure to scrub up under the ring at the top. When you are finished scrubbing, rinse off the brush in the toilet and let the excess drip into the bowl.
Step 2 - Storage
To ensure that your wall mount toilet brush has a long life, you can keep a bit of disinfectant or natural cleaning solution in the bottom of the wall mount so that the brush is always clean. Options are a diluted bleach solution or a mixture of water, vinegar and even lavender oil.
