How to Use Cyanoacrylate as a Filler
0.5-1
Beginner
- 2-5
If you want to fill a hole, and have some cyanoacrylate glue on hand, it can make a great filler. In order to construct a filling material from the adhesive, you will need to add some materials to it. There are a number of items that you can use to create this filler, including sawdust and bicarbonate of soda.
Step 1 - Use Baking Soda
Start by cleaning out the hole that you want to fill. You can use a cloth to remove any traces of dirt or debris which have been left in the hole. Once you are sure that you have cleaned the surface, add a teaspoon of baking soda to the hole. Keep adding baking soda until the hole is filled up. You should then take a drop of your cyanoacrylate, and place it into the baking soda. These chemicals will react together, creating an exothermic product, and some poisonous vapors.
Step 2 - Use Saw Dust
You can also use sawdust in a similar manner if you want to fill a hole in wood. Be careful of the heat produced during the reaction, and make sure that the item has cooled down completely before leaving it alone.
