How to Use Fuel Injection Cleaner
fuel injectors in automobile
Your fuel injector can become clogged up with deposits left behind from fuel and its additives. It is important to occasionally clean your fuel injector with fuel injection cleaner. Fuel injection cleaner is easy to use. Here are a few simple guidelines for how to use fuel injection cleaner.
What is the Fuel Injector?
The fuel injector supplies fuel for engine. Each fuel injections system is different since it is calibrated for a specific type of fuel. A cracked fuel injector can cause a fuel leak which will cause you to pay more for gas. A faulty injector restricts the flow of fuel which in the long run could cause your engine to idle or misfire.
Choose the Right Fuel Injection Cleaner
Not all fuel injection cleaners work for all engines. Shop around for the fuel injection cleaner that works best for your car or truck. If you have questions, ask your mechanic or a salesperson at your local auto parts shop.
Read the Directions Thoroughly
Before using any fuel injection cleaner in your car, always read the directions. Not all fuel injection cleaners work the same, and if used improperly they can cause problems. The directions will tell you how much fuel you should be using with your fuel injection cleaner.
Check Your Fuel Level
By now you should know how much fuel you need to have in your tank before using your fuel injection cleaner. Start your car and let your gas gauge settle in place. If you don’t have the proper amount of gasoline, then add enough to meet the requirements.
At this point, add the fuel injector cleaner to your fuel tank. The fuel injection cleaner will then work as you drive.
