How to Use Paint Sealant
painting a wall grey
Warm water
Sponge
Gentle detergent
Paint sealant
Paint brushes
Cleaning solution
Paint sealant is normally something one would associate with the exterior of a vehicle but it can also be used for home decorating. Essentially a paint sealant is comparable to a clear varnish, which seals paint behind an invisible protective wall. Paint sealant is easy to apply and takes minimal tools, materials, and effort. Of course this does depend on the size of the project that you painted and wish to seal.
Step 1 - Surface Preparation
wiping a wall with a rag
Prepare the painted surface by washing it with warm water and a gentle soap solution or detergent. It should be perfectly clean and dry before you attempt to use the sealant.
Step 2 - Use the Sealant
Apply the sealant with a paint brush as though you were using paint or clear varnish. The process is identical and the strokes should be gentle and even so that all the paint gets the right amount of sealant on it. The whole surface should be evenly coated before you allow it to dry or apply further coats.
Step 3 - Clean Brushes
Clean the brushes with an appropriate solution according to the instructions on the sealant packaging to keep them from degradation or hardening.
