Identify Asbestos Roof Tiles
A sign that says "Danger Asbestos."
  • 1 hours
  • Advanced
  • 60
Gloves
Respirator with HEPA filter
Soap and water
Protective clothing
Plastic container
Saw
Gloves
Soap and water
Protective clothing
Plastic container
Saw
Asbestos roof tiles can be dangerous. The main reason why asbestos roof tiles need to be replaced by safer alternatives is that the asbestos fibers used to build the material pose a health hazard when inhaled and when they come into contact with the skin. Although most asbestos products are not really hazardous per se, they can be when the fibers become airborne. Here are some pieces of information that you may find useful when identifying asbestos roof tiles.
Determine the Age of the Building
Asbestos was used from the early 20s to the late 80s. When a building is quite old, it has a good chance of having asbestos building materials. Since asbestos building materials cannot be easily spotted with the naked eye, the best clue is to find out when the roof was actually built. Asbestos was not fully recognized as a health hazard up until the late 80s when certain cancers were linked its exposure. Therefore, old buildings do have a big chance of having this hazardous material. Usual areas that use asbestos building materials include those that need protection from fire. Because of its flame retardant qualities, it has been used around fireplaces and even exterior walls and roofs.
What Color is Asbestos?
Asbestos is actually whitish, grayish, or whitish-blue in color. However, when mixed with other materials, it may be impossible to know whether asbestos has been added or not. Generally, tiles containing asbestos do have a gray, white, or bluish-white color.
Providing Samples for Lab Check
The only way to safely know whether the roof tiles contain asbestos or not is to have a sample professionally checked under a microscope that uses polarized light. When taking a sample, be very careful because asbestos dust can get into the lungs and cause cancer. Therefore, when deciding to get a sample, do so with certain precautions.
First of all, wear rubber gloves and a respirator with a HEPA filter. There are many asbestos testing kits available on the market. You can use these by following the instructions given. If you don't have this kit however, use a saw to cut a sample. To make the tiles safe for cutting, spray them with soapy water. The water will cause the fibers to remain intact even when the tile is cut. Find an inconspicuous area in the roofing and mark a square inch of tile. Cut the tile carefully and place it in a plastic container. Take the sample to an asbestos testing laboratory. The cost of testing a small sample is reasonable. If the tile has less than 1 percent asbestos, then the results are negative. Just to make sure, take two or three samples for comparison.
Removing Asbestos Roof Tiles
When replacing the tiles with safer options, do not do so carelessly. Make sure to prevent the fibers from becoming airborne. It is better to leave the task to trained professionals who can handle the situation safely. Unless you have the necessary skills, ask for professional service instead.
