Information About Attic Storage and Mildew Damage
Mold growing on a white wall.
Attic storage can be an efficient way of storing and safeguarding your seasonal belongings. However, it is important to be aware that the attic is subject to extreme temperatures. Therefore, you must make sure it is properly ventilated, so your belongings will remain in good condition.
Causes and Cures for Mildew
Excessive humidity and moisture cause the formation of mildew in the attic. The best way to prevent this problem is by being proactive about ventilation and air circulation. Check your attic for signs of dampness or moisture. Problems with your roof, clogged vents or downspouts, and lack of air circulation can all lead to the accumulation of humidity and moisture.
Correct the problem by installing roof vents, if needed. Install an attic fan to promote cross ventilation. An attic fan will let out excessive heat during the summer months and keep the humidity levels down.
Preventing Mildew
After ensuring that your attic is free of mildew and is well ventilated, you can start storing your belongings there. Never store media such as films, photos, or compact disks in the attic, however, as they will be destroyed by the temperature fluctuations. Avoid filling your storage containers to the brim. This will promote better air circulation.
Cover furniture with blankets for added protection. Avoid using wooden or cardboard boxes for storage, as these materials are susceptible to moisture damage. Avoid stacking heavy boxes on top of each other, as it will make it difficult to check the stored items for any signs of damage or mildew infestation. Finally, make it a point to check your belongings once every few weeks.
