In-Ground Pool Liner Options
If you have an in-ground pool, there are several liner options in different types and styles. A good quality pool liner will protect your in-ground pool from small debris and many types of contamination from seeping into your pool and will keep your pool from leaking or seeping water into the ground.
Types of Pool Liners
When you choose to install a pool liner for your in-ground swimming pool, you will have a couple of different options. For in-ground swimming pools, there are two primary types of pool liners: cement tile pool liners and vinyl tile pool liners.
Vinyl Liners
Vinyl liners are generally cheaper than tiles and are easier to maintain and clean.
Tiles
Many people choose to use the map tiles as they offer many more styling options and are generally considered to be more attractive in appearance. Furthermore, cement tile pool liners are usually more durable and hold up better for a longer period of time.
Installation
With in-ground pool liners, it is probably better if you have a professional do the work, rather than attempt it yourself.
