Installing Cabinet Hardware: What You Should Know
  • 2 hours
  • 50-75
Handles or knobs
Screws
Drill
Level
Measuring tape
Before installing cabinet hardware, take precise measurements of your cabinets and doors. This will help you avoid making unsightly extra drill holes that could lead to splintering. Follow these steps for easy cabinet hardware installation. In addition to the handles or knobs and additional screws, you will need a drill, a level, and a measuring tape.
Step 1 - Match
Find the drill bit that matches the thread hole on the door or drawer handle.
Step 2 - Pick the Location
Select the location where you want the door handle or knob to be. On a drawer, the best place for the handle is usually in the center. For cabinet doors, determine whether you want handles positioned vertically or horizontally.
Step 3 - Measure and Mark
Using a measuring tape, mark the two locations where you need to pre-drill. Make sure these two positions are even using a level.
Step 4 - Pre-drill
Pre-drill the holes for the door or drawer handle.
Step 5 - Place Screws
Put the screws through and tighten up to the handle. When fully tightened, there should be no play between the drawer and the handle.
