Installing Kitchen Sink Drain Plumbing
Adjustable wrench
Two adjustable water lines (measure for length)
Drain pipes with trap assembly (kit)
Medium pipe wrench
Bucket
Teflon plumber's tape
Towel
When installing a new kitchen sink or replacing a faucet, you should change the plumbing that is connected to your kitchen sink drain as well. Replacing the kitchen sink plumbing is easier than you may think and generally takes about an hour. Using a few basic household tools, you can replace the pipes and water lines underneath your kitchen sink in no time at all. Here is your step-by-step guide.
Step 1- Shut Off the Water
First, turn off the water supply going to the kitchen sink. You will need to locate the valves. They are typically below the water lines that lead to the hot and cold water faucets. Rotate the valve handles to the right (like you would tightening a screw).
Step 2 - Drain the Water Lines
Release the water from both the hot and cold water faucet by turning them on so that any water still in the pipes may run out of the lines. The flow should decrease and eventually stop. If this does not happen, it means the water was not shut off completely.
Step 3 - Disconnecting the Water Lines
Using your adjustable wrench, remove the hot and cold water lines from the faucet. Then, repeat the process for both water lines to disconnect them from the shutoff valves.
Step 4 - Disconnecting the Drain
To disconnect the drain from the sink, loosen the nut at the bottom of the sink drain with a pipe wrench. Then, slowly screw the entire pipe assembly from the area where it enters the main drain. This should be located somewhere near the center of the back cabinet floor. You should have your bucket ready to place under the drain assembly to catch the water that will fall from the S-trap. Be careful—this water will probably be dirty.
Step 5 – Taping
Using your Teflon plumbers tape, wrap the threaded end of the hot water faucet with a piece that is approximately six inches long. Repeat the process for the threaded end of the cold water faucet.
Step 6 - Connecting the New Water Lines
Now you can screw the new water lines onto the threaded pipes leading to the hot and cold water faucets. Again, wrap Teflon tape around the threaded ends of the shutoff valves, and screw on the hot and cold water lines.
Step 7 - Connecting the Drain
Attach the bottom part of the drain assembly onto the main drain, which is located at the bottom rear floor of the cabinet. However, do not tighten it yet. Then, adjust the height of the drain assembly to where each side meets the appropriate hole on the bottom of the sink.
New kitchen sink drain
Step 8 - Securing the Drain
Next, using a pipe wrench, screw each side of the drain pipe assembly onto the bottom of the sink drain and tighten until it is snug and secure. Make sure you do not tighten the nuts too much or they will leak. Then, fasten the bottom drain assembly where it connects to the floor drain. Again, do not tighten it too much.
Step 9 - Turn the Water On
Now rotate the shutoff valves to allow water to come back into the pipes. Then, open the faucets and check the entire drain, drain assembly, and both water lines for leaks. If there are drips or leaks, tighten the connection slowly until the dripping or leaking stops.
Congratulations—you have now installed the plumbing for your kitchen sink! Now, use your sink with a renewed sense of pride knowing that you did it yourself.
