Kitchen Cabinet Makeover with Beyond Paint
kitchen with painted cabinets
Sponsored Article
BEYOND PAINT ® makes updating your kitchen not only easy but cost-effective too! With regular paint, you would end up spending hundreds of dollars between primers, sanders, and multiple gallons to complete a large kitchen.
A gallon of Beyond Paint is ideal for Medium to Large Kitchens with over 20 cabinets. We say that if you’re not quite looking to spend thousands on replacing cabinets and want to invest in other areas of your home, then a DIY refinishing project in your kitchen is an ideal solution.
kitchen cabinets before painting
The paint is an ALL-IN-ONE water-based refinishing paint formulated with advanced nano-particle technology perfect for anyone wanting to complete home improvement projects in less time, with less effort, for less money that will achieve professional, durable results with no stripping, sanding, or priming required.
Beyond Paint ® works on virtually any surface, whether it’s furniture, cabinets, counterops, and more—their formula covers it all. It is specifically formulated as a bonder/primer/finisher that cures to a durable, washable surface in just one or two coats.
Application is quick and easy, and the result is a beautiful, professional finish that will transform your home.
Below we will show you how easy it is to get started.
hands preparing cabinet doors for painting
Clean with: Mineral spirit or an all-purpose degreasing product. A household degreaser is the best choice to clean the surface prior to painting.
How to: BEYOND PAINT® formula is thick, making it great for coverage as well as durability. A small brush can be used to stipple areas that the roller can’t reach.
However, using a roller as much as possible will allow for a nice even finish. No Stripping, No Sanding, and No Priming when you choose BEYOND PAINT®! Two coats are recommended.
hand painting cabinet door with small roller
Recommended Tools
4-inch roller with 3/8 nap
All Natural Soft Bristle Brush
Paint Tray
Or BEYOND PAINT® Toolkit
BP paint supplies
*1 Gallon BEYOND PAINT® covers 200 sq ft (40-48 Cabinet Doors & Face Frames with 2 coats!)
*1 Quart BEYOND PAINT® covers 50 sq ft (10-12 Cabinet Doors & Face Frames with 2 coats!)
*1 Pint BEYOND PAINT® covers 25 sq ft (5-8 Cabinet Doors & Face Frames with 2 coats!)
*Allow 2-4 Hours between coats. Beyond Paint can take up to a week to become scratch-resistant and fully bond to the surface, and after 30 days, it is fully cured to a washable/durable surface.
Recommendation if spraying: HVLP system with a wide nozzle.
person using spray gun to paint cabinet doors
