Kitchen Cabinet Remodeling Ideas
Kitchen cabinet remodeling can transform a tired and dated kitchen very easily and at a much lower cost than a complete replacement. Changing the look of your cabinets also gives you the opportunity to be creative and unique in your design. This article provides a few suggestions on how to update the look of your kitchen’s without spending large sums of money.
Refinishing Kitchen Cabinets
The easiest way to update the look of kitchen cabinets is to give them a fresh finish. Stripping back the existing top coat will allow you to re-apply a stain or color of your choice, instantly giving your cupboards a fresh new appeal. This process can be time consuming, but if it is done carefully, it should produce a good quality finish with a long shelf-life.
Stenciling
Stenciling your kitchen cabinets provides an opportunity to apply some creative flair to your living space. Stencils can either be store purchased or made yourself by using cut pieces of cardboard or tracing paper. Either method offers a cost-effective alternative to replacing your entire kitchen cabinet.
Self-Adhesive Veneers
Self-adhesive veneers are a simple alternative to completely re-facing your kitchen cupboards. Serving as a cheap alternative to real wood, these stylish and modern veneer coverings have a realistic wood-effect appearance and are simple to fit. Kitchen cabinet remodeling can be as simple as applying a layer of thin plywood to existing surfaces to accommodate repairs, and cutting the veneer to size before adhering it to the outer framework. This method doesn’t require the use of any specialist tools and helps to keep the costs down.
Self-Adhesive Plastic Coverings
One of the simplest methods of covering tired cupboards is to use a self-adhesive plastic covering which can be bought in rolls from any good hardware store. This inexpensive option for recovering can offer a multitude of finishes from glossy colors to real wood effects. This style of kitchen cabinet remodeling involves spreading a section of colored or patterned plastic onto the cupboard surfaces and flattening it down evenly while avoiding the build-up of air bubbles. It can be a tricky procedure to get right, but, with patience, the effect can really be worth the effort.
Paint and Grain
This is a painting method designed to produce a wood grain effect on kitchen cabinet surfaces. It is created by covering the primed surface of the cabinet with a light color of wood paint as a base coat. The grain effect is made by dipping a specially designed comb or graining tool into a darker feature color and dragging it in a rocking motion down the wood. This process should be repeated in sections, all in the one direction, and the ultimate finished look is similar to a piece of paneled wood.
Super Gloss Spray Paints
One of the quickest ways of implementing your kitchen cabinet remodeling ideas is by using a touch of spray paint. These cans come in a wide variety of colors and textures and as long as the working surface is clean and dry, they will provide a fast, effective covering for most wooden surfaces.
Find Trusted Professionals For Your Kitchen
