Knowing When to Use a Time Delay Fuse
- Beginner
A time-delay fuse is a special type of fuse which is designed for specific applications. Fuses are an important part of every electrical system as they protect the user from electrocution and fire. The size of the fuse is carefully chosen to suit the requirements of the appliance or circuit.
If more power is being drawn than there should be, the fuse blows. Traditional fuses use a mechanism similar to a light bulb. A thin wire is used in the fuse, which is the right size for the amount of current being drawn. If any more is drawn then the fuse will burn out and blow, resulting in a dead circuit.
Purpose of a Time Delay Fuse
A time-delay fuse is also sometimes known as a slow blow fuse. The purpose of this type of fuse is to allow a surge in electricity for a short time before the fuse actually blows. To many people, this sounds like a bad idea. However, it's beneficial and actually much safer for certain types of electrical appliances.
These time-delay fuses are designed for specific applications and it's not normally possible to fit a different fuse inside the receptacle.
How They Work
Part of the fuse works like a normal fuse that has the burnout link, but in addition to this, there is a short connector that has a spring attached to it. This spring is soldered onto the fuse wire. These can cope with an overload of 100 or even 200 percent of the normal load without causing any harm to the elements.
If the overload remains for a long time, then this will cause the solder joint to melt. This will, in turn, open the contact.
Motors
An electrical motor takes a lot more electricity to start than it does to continue operating. This means that a slow blow fuse is a great way to protect the circuit.
Fluorescent Lamps
A fluorescent lamp will also consume much more power when it is first switched on. This will then decrease over time when it is left on. This is why a slow blow fuse can be beneficial in these cases. Anything that has a coil or starter motor inside will consume more power when starting up than when it's running normally.
Why Is a Slow Blow Fuse Safer?
If it wasn't for slow blow fuses, then you would need to use a higher rated fuse to cope with the initial load of the light or motor. The downside of getting a higher rated fuse is that it would also mean that the fuse is too big for the normal load of the light, and risk overheating during a malfunction.
This could potentially be dangerous because it could mean that the fuse will not blow when the circuit is overloaded. A slow blow fuse will only allow an overload of a specified amount, for a specified amount of time. Anything that goes over those specs will result in it blowing and cutting off the circuit.
