Live Bamboo Fencing
Live bamboo fencing is a great way of adding privacy around your home and yard. Bamboo is very tough, easy to grow, and is very attractive. Its exotic beauty is reason enough to try and plant a bamboo fence in your backyard. Detailed below are some of the important points to consider when planting a live bamboo fence.
Selecting the Right Species
Bamboos can be broadly grouped into two categories. The first is the running variety, which grows very fast and can be quite invasive if not controlled properly. The second is the clumping variety, which is slower to grow, but is easier to contain within a specified boundary. Running bamboos provide a quick and tall fence, but they may require more work in terms of containment. Some of the popular species that can withstand most weather conditions include Black Bamboo, Golden Bamboo, Meyerii, and Arcana Bamboo. Before you decide on a certain species, ensure that it will do well in your weather conditions.
Planting a Live Bamboo Fence
If you live in a cold climate, you must plant your bamboo fence in early spring, after the last frost. This will prepare the plant for the next winter. In hotter climates, plant the bamboos when the weather is milder and not too hot. Spring and fall are both acceptable times, but fall is preferable. Choose a variety of bamboo that is suitable for growth in your area.
Before plating bamboo, you must prepare the ground. Work some compost or fertilizer into the soil beforehand. Using spray paint, mark the area where you plan to plant the bamboo. Plan your pattern beforehand. You can even use different species of bamboo in alternating order for a unique look. If you are planting a running variety, you must use a rhizome barrier, which controls the spread of invasive bamboo rhizomes. Install the barrier around the planting area.
Dig holes in the soil, about double the size of the bamboo root balls. Place the plants in the hole at the same heights they were in the pots. Cover up the holes with soil and fertilizer mix. Sprinkle some mulch around the plants and stake them for support during the initial stages of growth.
Pros and Cons of Live Bamboo Fencing
Live bamboo fencing is considerably cheaper and more long-lasting than most wood or metal fences. You can keep it for as long as you want, provided you take proper care of it. There are several different varieties and looks you can choose from. Best of all, it is environmentally friendly and it reduces airborne pollutants in the vicinity of your home by absorbing carbon dioxide.
It is important to keep an eye on your live bamboo fencing to ensure that it is not spreading beyond your property. Regular pruning and removal of young shoots may be necessary, especially with the running varieties of bamboo. Water your live bamboo fence during hot weather and fertilize it a few times every year. With proper care and maintenance, your live bamboo fencing will become the most treasured aspect of your backyard.
