Maintaining and Caring for Your Steam Shower Unit
A shower steam unit is a luxurious item that requires proper care and maintenance in order to guarantee a long lifetime. When a steam shower unit is damaged by improper care and maintenance, it will cost a lot of money to repair it.
Steam shower units rely on electricity and a continuous supply of water in order to run smoothly; therefore, it is important to check the power lines, the water supply pipes, and the generator for any issues that may lead to damage. Cleaning inside the shower is also important. Here are the best ways to care for your steam shower unit.
Cleaning the Unit
Cleaning is an important maintenance procedure because it keeps the unit mold and stain free. Since steam showers produce moisture, they need to be cleaned and dried regularly. Stains and mold growth can be cleaned using all purpose cleaners or simple home remedies, such as vinegar cleaning solutions.
Inspect the surface for eyesores and clean them using a rag dipped in cleaning solution. Provide ventilation in the room where the unit is installed. Install an exhaust fan or open the windows every once in a while to provide air circulation. Allow the unit to be opened to make sure that the moisture escapes.
Changing Heating Coils
After long periods of use, heating coils in the steam shower unit may lose their efficiency and heating function. If the steam showers produce relatively lower amounts of steam, then the heating element or device may require cleaning or replacement. If so, have the heating element inspected and replaced if necessary.
Inspecting the Water Lines
Water is a very important factor in a shower; therefore, the water supply pipes should be checked for leaks. Any leak in the water supply line can cause the steam generator to produce less steam pressure. That may affect the overall performance of the unit and disappoint anyone who is taking a steam shower. Inspect the supply pipes for leaks and loose connections. Tighten the fittings and seal the leaks as soon as possible. Remember that shortage of water during the operation of the unit may cause damage to the unit.
Inspecting for Tightness of Seals and Joints
Silicone seals, water supply joints, valves, and nozzles should be checked at least once a year. If the silicone seals are loose, replace them. Sealing the doors and walls is quite easy. Nozzles, joints, and drainage systems can be tightened or repaired using the most basic plumbing skills.
