Marble Floor Restoration in 3 Steps
4 hours
Intermediate
- 150
Marble floor restoration may be required if the floor in your home is stained, dull, and unsealed. Despite its hardness, marble is a porous stone and can be stained easily by colored liquids or acids. Since the floor also receives a lot of foot traffic, it can lose its shine in time. The constant traffic will also cause the previously used sealer or impregnators to lose effect. For a quick guide to marble floor restoration, read the steps below.
Step 1 – Clean the Stains
Clean dirt, grime, and stains using a mop soaked in warm water. Simply mop the floor to remove the dirt and grime and allow it to dry. However, this may not be sufficient when you are dealing with old stains that have never been cleaned. Stains from coffee, wine, and acids are also a lot harder to remove. In order to clean these, make a mixture of water and baking soda that you can apply on top of the marble floor and allow it to sit for about one night. The mixture will suck the stains out of the pores and allow them to be removed. In the morning, mop the affected area, let the floor dry, and clean with a vacuum cleaner.
Step 2 – Polish the Marble
Polishing the stones to produce a new look is the next step in the restoration process. Marble polishes come in many forms. Some are mixtures you can apply on top of the floor surface. However, if the marble needs to be polished heavily, consider using a diamond marble polisher. This abrasive tool can be rented from an equipment rental store. Keep in mind that the polisher will remove a thin layer of the marble to deal with scratches and irregularities. Diamond marble polishers work like fine-grit sandpaper and can make the marble look shiny and new.
Step 3 – Seal
Apply a marble sealer or impregnator (this step is optional and up to the homeowner). Just remember that sealing will protect the floor from contaminants that cause stains. The sealer will last for about two years or so depending on the amount of traffic the marble floor gets. Carefully choose the type of sealer you will use because some sealers can cause discoloration. Talk to an expert on this matter to get the best advice and never use an ineffective sealer on the floor. Choose only from the recommended products on the market.
More Tips for Marble Floor Restoration:
Although marble floor restoration is an important aspect of marble maintenance, remember that regular cleaning is also essential. Always make sure you clean the floor immediately after a contaminant falls on the floor. Never allow acids to touch the floor as well. You should not use cleaning products such as salt, vinegar, and lemon juice for cleaning because they can damage the stone.
