Contrasting Dark Furniture Color with Livingroom Walls
A dark red couch against a cream colored wall.
Interior design has as much to do with furniture color and style as it does with the color of the walls, ceiling, and other decorative elements. A well-designed room contains complementary features, of which the furniture and the walls are the biggest components. In the living room especially, where your guests are introduced to the decor of your home, it is important to work with collaborative contrasts.
One way to do this is to utilize the two dominant features, furniture and walls, to create a smartly blended atmosphere. Dark furniture surrounded by dark walls shrinks the room in addition to drowning the furniture in obscurity. The same is true for light furniture against light walls. While you want to match colors wisely, contrast is as important as the combination.
Color Matching
Unless you have furniture custom made, available colors for upholstery are limited according to the current fashion. There are still numerous colors to choose from though. Opting for dark furniture, your color choices range from darker browns and blues to forest or olive green, deep purple to maroon and from slate to black. The darker end of the spectrum is more varied, but your main choices fall somewhere in there. Pick your furniture out first.
Wall color is easier to adjust than your furniture. Once you have your furniture, begin to plan out the color or colors for the walls. As mentioned, contrast is important. Do not pick the same color for your walls as you did for the furniture. Warm, light-colored walls do not go well with cool, dark-colored furniture. Consult a color wheel with the basic 12-tone spectrum that extends out in all directions as a good way to determine working pairs.
Dark Furniture, Lighter Walls
The rule is: with dark furniture, go with lighter walls, but as with any rule, it can be bent to a certain extent. The exact colors will depend upon the color of the furniture. The contrast should not be excessive. A wide range between the colors will be offensive to the eye. The point is, the walls should be lighter than the furniture. That may mean by just a few shades of one particular color.
Balance out the contrast by choosing a color for the trim, molding, and baseboards that is different from the walls but not shockingly different. Rugs and curtains must be considered too. You don’t want too much of one shade in one place. Rugs that match the walls and curtains that match the furniture are a nice touch.
Interior design requires some thought. It is not just a matter of cobbling together a few pieces of furniture and slapping on a coat of paint. If you want your living room to create an atmosphere of unity and grace, matching colors to create a potent scheme is vital. Your living room is in charge of first impressions in your home, so it is worth the creative effort to arrive at a winning combination.
