Matching Light Furniture Color with Livingroom Walls
light grey couch against dark grey wall
Matching walls with a light furniture color is a matter that requires some interior design work and color coordination. In a living room, it is important to make a good impression on visitors, for this is the room they will likely see first. Color schemes can vary widely, and much of the decision hinges on your personal tastes. There are, however, a few rules governing the placement of color in a room as well as what to do when matching furniture with the walls. Those two elements are not the only thing in a room that fits into the design scheme, but they are the most integral. Rugs, carpets, curtains and trim all weigh in to the design as well, but their colors are largely dependent upon what you choose for the walls and the furniture.
Matching Light Furniture Color with Living Room Walls
If you have light-colored furniture in the living room, before redecorating the walls, consider some design basics. Having light walls to match light furniture will wash the latter out. It is not that you won’t know where the furniture is, but nothing about the room will stand out. Effective color contrast is a main priority when laying out the design of a room. Thus, the first rule is: contrast light furniture with walls of a darker shade.
Light Furniture with Darker Walls
biege sofa against purple wall
This is not to say that the walls should be the darkest shade possible. However, they should be noticeably darker than the furniture. If, for instance, you have furniture in collegiate yellow, which is a fairly light shade, going darker than this for the walls will balance out the room and give a healthy contrast to the atmosphere. A darker shade of yellow green would be a nice touch with that variety of yellow. Of course, the most neutral color for furniture is white, but white furniture has a sterile look, and it shows even the smallest stain. Most light furniture is at least off white or raw umber if not a light shade of yellow, green or some other soft, warm color. When matching the furniture with the walls, stick with like shades. Here is the second rule: keep warm with warm and cool with cool. Otherwise your living room will seem too disjointed.
Like Colors Go Well Together
A soft sky blue goes well with a light green or violet. Matching it with some shade of yellow, orange, or red creates a chaotic room where the eye cannot discern any pattern. Keep warm colors like yellows, reds, and oranges together as well. Doing so will ensure the room’s design is pleasant and in accord with itself.
Rugs, Curtains, and Trim
modern and open living and kitchen space
With light furniture goes darker walls. Next, consider how the room’s rugs, curtains, and trim fit into the design. A rug often will match the walls, while the curtains will balance out the room being closely matched with the furniture. That leaves the trim, molding, and baseboards. Off white is suitable for these features, for it is so neutral, but you may opt to add another color element to the room. Don’t overload it with too many colors, though, or else it will seem too busy.
The biggest rule to remember if you have light furniture in your living room is to contrast it with walls that are darker. The difference may be minimal in terms of how much shade is present in the walls, but it should be enough to be noticeable without being stark.
