No Heat Vinyl Leather Repair Kits: Pros and Cons
When undertaking vinyl leather repair, you will be faced with plenty of options on different repair kits. Some use heat, but there are a number of people who prefer the heat-free option. It offers a series of advantages and disadvantages that need to be considered before you spend your money. Ultimately, however, the questions to be asked are just how well no-heat repair kits work and how easy are they to use.
Pros
With a no-heat kit, the price for vinyl and leather repair is very agreeable. For those on a budget who can’t afford a professional repair and are wary of heat repair, this is a great advantage. Once you know how to use the kit, repairing torn leather is quite an easy job. It will take some practice and fair degree of skill, but it’s very easy to master.
Done properly, the repairs can look great. Although it’s true that no-heat kits are not a match for a professional job, they will do a respectable job and keep the furniture or upholstery looking attractive.
The kits are quite comprehensive with a range of colors and finishes that can offer a very reasonable match for most finishes. Manufacturers provide close matches to the most popular colors of leather and vinyl, but the nature of the kit means they’re slightly limited. However, there should be ample choice for the vast majority of colors.
You can do the repairs at home. There’s no need to move the furniture to the repairer’s workshop, so you can carry on using the seats. This is especially important if you’re repairing car upholstery. In general, the repairs take less than one hour, so they can be carried out in the evening or when you have some free time.
Cons
torn piece of grey leather seat in a car
There’s a learning curve involved in becoming proficient with no-heat kits, and that’s not ideal when working on vinyl and leather repairs. You need to spend time practicing first in order to do a good job on the repair.
The simple fact is that the repair job, though adequate, will look as if it was done at home. It will be sufficient but no more than that. For something undetectable, you will need to use a professional and with expensive furniture, this can be worth that extra investment.
However hard the manufacturers try, the range of colors and finishes in the kit can’t match anything beyond the most popular colors. In many instances that means you’ll only achieve an approximate match, which will be fairly obvious to the naked eye.
It can be advantageous to carry out the repairs at home and will certainly be more convenient, but nothing can beat a professional job. Professionals cost money but the results always prove worthwhile. Vinyl leather repairs are a classic case of getting what you pay for. In a no-heat kit, the vinyl and leather repair you get is adequate but nothing more. However, when you’re paying just a few dollars, you can’t expect something that will produce perfect results. If you don't expect too much, you won’t be disappointed.
