Oriental Rugs: Removing Pet Stains and Pet Hair
An oriental rug.
  • 2 hours
  • 0-100
Damp paper towels
Rubber gloves
Rubber squeegee
Lint remover or anti-lint brush
Duct or packaging tape
Cold water
Vacuum cleaner
Crumpled newspaper or wood
Damp paper towels
Rubber gloves
Rubber squeegee
Cold water
Vacuum cleaner
Your oriental rugs can be ruined by your pet's stains and hair. Below is a short and easily followed step-by-step method of taking out pet dirt and stains.
Clear Away Visible Pet Stains and Hair
First, quickly remove from your oriental rugs as much pet fluff and dirt as you can. You can do this by rubbing the affected spots with moist paper towels. To protect your hands from bad odor and dirt, put on a pair of rubber gloves before cleaning your rug. Pet hairs tend to stick to rubber, making your efforts a lot easier.
Dilute Stubborn Dirt with Water
If damp towels don't work effectively, you can try putting some water on the affected area. This will dilute the pet stain and can significantly clear away stubborn dirt. The amount of water that you can add depends on the size of the stain. But whatever you do, avoid getting your rug drenched.
Use Squeegee or Lint Remover
If you still see pet hair lodged within the rug pile, use a rubber squeegee to evenly brush off fluff from pets. Again, rubber tends to attract hair, so you will not have a hard time taking off strands of fur from your carpet or rug. For very fine cat hair, you can use a lint remover or an anti-lint brush.
If the affected oriental rugs are small, you can use a strip of packaging or duct tape. Simply put on the strip of tape on the area where there are lots of pet hair, then after a few seconds, pull the tape off.
Clean Off Pet Urine Thoroughly
Pet urine can bring about serious problems to your rug unlike any other type of dirt and stains. For this reason, pet urine deserves its own step in cleaning rugs. Urine can actually alter the composition of the dyes used in rugs, so you have to thoroughly blot out affected spots and in the fastest way possible. You can use water and some white vinegar to take out the odor and stain, but remember to remove as much of the vinegar solution as you can after.
Completely Dry your Wet Rug
If your oriental rugs became soaked with water, you have to ensure that they're completely dry before putting them back. You should lift up the affected area for a few hours to enhance air circulation underneath it. This will speed up the drying process. Put crumpled newspaper or two pieces of wood under your rug to hasten its drying.
Vacuum It
After the rug has dried, you should vacuum the affected area to take out dust and other particles. Vacuuming can also bring back the softness and silky feel of your rug.
