Permanent Wood Foundations Explained
wood foundation
Foundation repair issues can be minimized if permanent wood foundations are installed. Establishing permanent wooden foundations usually involves the use of treated lumber. Panels of wood are pressure-infused with special chemicals commonly referred to as preservatives.
This chemical treatment is useful for protecting the wood against foundation maintenance issues such as mold infestations and decay due to moisture. The panels are strengthened with wood fasteners made of stainless steel that are impervious to chemical and moisture induced corrosion.
Understanding Wood Foundation Attributes
Wood is a much better choice than concrete for establishing durable foundations. Wood foundations offer better resistance when subjected to neglect and tend to offer better thermal insulation as well.
That makes them ideal for homeowners who want to create a foundation system that needs minimal maintenance and contributes to energy conservation within their home. Wood foundations are more elastic, making them less susceptible to cracking under weather-induced problems such as expansion and contraction.
The elimination of concrete foundation-based components makes wooden foundations a more affordable option. Permanent wooden foundations offer many other advantages.
Installation and Handling Ease??
Wood foundation panels are much lighter than concrete blocks. They can be easily placed over gravel beds which have been fortified with crushed stone bits and coarse sand. Doing so eliminates the need to prepare the cemented footing that is common in concrete foundations.
It also reduces the installation time. Basements prepared with wooden foundations are easier to maneuver for internal insulation. Wooden foundations are more adaptable to the addition of insulation materials such as cellulose layering.
Adding batts is often recommended for insulating the foundation. Applying batts is very expensive among concrete foundations, as industrial adhesives and specific studs are needed to bind the batts with the concrete.
Batts are easy-to-install within wooden foundations. Working with wooden surfaces makes repairing of basement-based, plumbing and wiring easy. Wood joists are also easier to handle during HVAC installation.
Repairing and Finishing Ease??
Concrete foundation repairs require casting and curing that is often weather dependent. Wooden foundation installation and repairs can be executed in any weather because weather-related problems associated with concrete foundations are eliminated.
Precut wood panels are installed with framing screws that can easily replaced if a panel appears to be slightly destabilized. This task can be completed with basic household tools without the need to employ professional help.
Wooden foundations can be easily finished. The finishing is usually undertaken by the foundation installation and carving contractors. In this case, finishing doesn't need chase construction, masonry adhesives, or complex cutting gear that is used for concrete finishing. In fact, wood-foundation finishing can be done by homeowners themselves. Many easy-to-follow foundation-finishing kits are available at hardware supply stores.
Unquestioned Warranty and Reliability
Wooden foundations have created a niche for themselves in the residential foundation marketplace. As a result, they are often retailed with extensive warranties. Most analysts believe that contemporary wood foundations offer long-term durability, usually lasting for many decades.
The durability of permanent wood foundations has been underlined by many official certifications of global repute, such as the International Residential Code. Wooden foundations have constantly met the benchmarks set by the American Wood-Preservers' Association; furthermore, permanent wood foundations are usually compatible with the most demanding of building codes and insurance clauses.
