Pet Carpet Odor: What Types of Carpet Are Easiest to Remove Pet Odor From?
Dealing with pet carpet odor is one of the most common problems for pet owners. Carpet is typically bad when it comes to absorbing odors, and if you have a pet, it can multiply this problem. While most carpet absorbs pet odor, there are some carpets that are better than others when it comes to removing it. Here are a few of the best carpets for removing pet odor from.
Commercial Carpet
One of the best carpets when it comes to cleaning pet odor is commercial carpet. Commercial carpet is very tight and compact. This is the flattest type of carpet that you can get. It is woven very tightly, and there is not a lot of room for things to get down in between the fibers. Because of this, it is one of the easiest carpets to clean in most cases. There is not as much fiber there to soak up liquids or anything else. Therefore, when it comes to cleaning pet odors, this carpet should do better than most.
Triexta
Triexta is a new type of carpet fiber that recently came on the market. This is the first carpet fiber that has been given its own class in many years. This type of fiber is naturally stain resistant. They do not apply any stain protection to it because it cannot absorb any liquids. With this fiber, you are going to be able to clean pet odors very easily. This fiber is environmentally friendly, as a good portion of it is made out of corn. It is also very durable and is equal to nylon when it comes to durability. This type of fiber is also sometimes referred to as Smartstrand which is a brand name for it.
Berber
Berber carpet is another type of carpet that you can remove pet odors from. Most Berber carpet is made out of olefin fiber. Olefin is good at not allowing stains to soak into the fiber. The area where it falls short is with grease spots. However, when it comes to pet stains, you can usually clean them up pretty well. Since most Berber carpet is very tight and compact, it is not going to be able to absorb a lot of stains. It is important that you try to clean up the stain or the odor as quickly as possible.
Odor Neutralizing Carpet
There are new carpets that are actually designed to repel odors. These carpets have chemicals in them that are designed to absorb odors and neutralize them. The good thing about these carpets is that they come in practically any style or texture that you can imagine. Therefore, if you are one of those people who likes a little bit more cushion under your feet, this is going to be a good way to go. Most of the time, this carpet is going to be a little bit more expensive than other carpets out there, but it will help you avoid pet odors.
