8 Tips for Planning an Upstairs Bathroom
Remodeling a house, especially planning to add a bathroom, always involves a lot of thinking and planning. You have to consider the space available, the current rooms, the layout of the house, budget concerns, and the theme used in the house. Depending on the type of room at stake other strategies have to be considered as well. If you want to add a bathroom, a major plan is to consider the connections to the pipes for water and drainage, but several other deliberations come into play.
Explore the Space Available
The main starting point is to see if the house has an area which can serve as the space to accommodate the new bathroom. Sometimes there are rooms which are not made use of, such as an extra bedroom, box room, or attic. If such a room or space is found, try to plan out how the bathroom utilities can fit in to try to utilize the space available as best as possible. It might be that there is only room for a toilet and a sink, and no space for a tub or shower.
Calculate Expenses and Set a Budget
The next step is to visit bathroom outlets to get an idea of the types of models and themes currently available on the market, and their respective prices. You may wish to retain the overall theme of the house or else experiment something totally new. Then calculate how much you can afford to spend and compare that threshold to the prices on the market.
Ask for Expert Advice
You may wish to consider talking to an architect in order to see that everything is according to prescribed rules and regulations within the parameters of the house permits. It is also best to have a plumber make sure that the connections with current pipes serving downstairs bathroom will not cause any problems, because if so one might have to consider installing new pipes.
Choosing the Tiles
In order to lessen the time involved laying tiles, opt for larger tiles. Keep in mind that you keep a standard color scheme, so try to match the tile color with the bath, sink, and toilet. Also make sure that the material of the tiles is easy to clean and does not show off the smallest amount of dirt.
Choose a Bath or Shower
Consider whether it will be more appropriate to have a bathtub or a shower, depending on the exigencies of the people who will mostly be using the bathroom, and more importantly according to space.
Consider Purchasing a Sink Vanity Unit
Rather than opting for a normal sink, you may wish to consider purchasing a sink vanity unit so as to have the possibility of being able to store things such as soaps and shampoos.
Storage Considerations
Another storage tip is to consider carving out part of the wall to have an enclosure to put in bathroom necessities. A good idea is to install shelving too since they take up wall space rather than floor space. The mirror can also accommodate shelves.
Install an Exhaust Fan
Such a fan helps to suck up the steam and condensation. This is especially ideal when there is only a small window or little ventilation.
Besides these recommendations, remember that the bathroom will add value to your property, thus it is fundamental to give it a lot of thought and to make it a point to plan the whole project carefully from the start.
