Plastic Louver vs Wooden Louver
Lead Image for Plastic Louver vs Wooden Louver
The louver is an important feature for air ventilation purposes. It is also used to regulate light and noise levels for rooms. Louvers are generally found on the windows, doors, and walls of buildings. They resemble shutters with a slatted opening. Horizontal or vertical slats on the shutter act to regulate the light and air allowed into a room. At the same time, the shutters limit noise from outside or an adjacent room from infiltrating into a room. Plastic and wood are frequently used materials for making shutters. Below is a comparison.
Plastic Louver Advantages
Plastic shutters cost less than the wooden variety. It makes an affordable choice for many. Plastic shutters can be produced to closely resemble an authentic wood product without the knots that are usually evident on wooden items. Plastic is 100 percent recyclable, unlike wood. The use of plastic shutters supports the sustainable utilization of natural resources. This makes it a more eco-friendly material for shutter use. Plastic shutters have a high resistance to moisture. Constant exposure to rain or moisture does not impact adversely on plastic shutters. This gives plastic shutters an edge over wooden shutters. Plastic louvers are a low maintenance feature. Once installed, they require little to keep them in good condition. You needn’t paint or stain them to maintain their condition.
Disadvantages of Plastic
With plastic louvers, you are limited in color choice. You cannot paint or stain plastic shutters, unlike wooden shutters which can be painted to whatever color you choose. The restricted color selection can be frustrating when you want to experiment with different colors. Although plastic shutters are low maintenance, window maintenance work is more difficult to undertake with plastic. Plastic louvers aren’t as resilient or durable as the wooden variety. High temperatures cause strain to plastic shutters. They easily lose shape and spoil the beauty of the house. Once they begin to wear down, there’s little you can do to restore them. You’ll be compelled to replace them.
Wood Louver Advantages
Wood is a warm and natural choice for shutters. It blends well with a variety of architectural styles. Once treated, wood will last for several years. This makes wooden shutters amongst the most durable. When the luster of wooden shutters begins to fade, you can easily restore the new look with a fresh coat of varnish or paint. A color change is quickly achieved by a painting job. This done, your wooden shutters will continue to serve for years to come. Plastic shutters do not give this flexibility. It is also easier to undertake window maintenance work where wooden shutters are installed.
Disadvantages of Wood
Wooden shutters cost more than the plastic variety. Wood has a low resistance to moisture. It rots easily when frequently exposed to moisture. Extreme temperature changes also cause wooden shutters to warp or splint. Wooden shutters are a high maintenance feature. You need to paint regularly or varnish to preserve them in good shape.
