Precast Concrete Steps: Pros and Cons
Precast concrete steps are a type of structure that is very popular in construction. These steps are called so because they are cast and cured in advance in a factory setting. Once the steps are manufactured and cured completely, they are taken to the building site and installed as required.
Advantages of Precast Concrete Steps
Precast concrete steps are highly convenient and suitable for most applications. Once the site is inspected and measurements taken, the steps are manufactured by filling concrete inside a mold of the required size. The steps are then dried and cured under strictly controlled settings. This enables better quality and more uniform appearance. Precast concrete steps are considered more environmentally friendly options. The construction site remains free from dust that would be generated by mixing concrete. The stairs can also be used right after installation as the curing process is already complete.
Disadvantages of Precast Concrete Steps
Higher cost is one of the prime drawbacks of precast concrete steps. It is important to ensure very accurate measurements beforehand. If the measurements are not correct, the steps will not fit in place. The lifting of heavy concrete steps can be detrimental to workers, which is why lifting equipment is required on the site.
