Prefabricated Stairs: Better than Custom?
Wood stairs.
When it comes to installing stairs, you may be divided between getting a custom build, or buying prefabricated stairs. The custom-built staircase has many advantages, including allowing you to fit a staircase into a difficult corner, or add extra steps if you have very high ceilings. Prefabricated stairs, on the other hand, can be much more easily installed and positioned, and you will have a secure set of stairs for your basic needs. Choosing the right style and make of stairs for you can be difficult, so knowing how to decide between these two types of stairs is very important.
The prefabricated stair kit allows you to buy and install a staircase without having to worry about fitting the treads correctly or measuring for risers. This kind of staircase is probably best when you need a basic set of stairs to get you up and down. While not designer, and usually very plain, these are the kind of stairs that you would put into the house if you were remodeling a home to update it, or restoring the shell of a building.
Advantages to these kinds of stairs include the reduced cost, the ease of personal installation, and the benefits of having a good, solid set of stairs that can be used by all the family.
Custom Stairs
Custom stairs are built to order. If you have a house that needs a staircase in the corner of the room, then you may have trouble finding prefabricated stairs to fit the space available. In this case, a custom staircase would be perfect. You could have it planned by a designer and made by a carpenter or metalworker to fulfill your design needs.
Fitting the custom stairs is usually too complicated for anyone who is not a professional, and a poorly made set of stairs can be dangerous, so you will need to get top-quality manufacturing products out of your stair makers. In addition, a custom-built staircase is usually exceptionally expensive, and you may find that you are paying for a complex design that does not suit the look of the rest of the house.
Choosing the Right Stairs
When you are looking for stairs to fit into a house, it can be difficult to know which is best for you. For those looking for cost-efficient, no-frills staircases, prefabricated stairs are ideal. If you are restoring an old home, or want to give a modern house a traditional feel, then custom stairs can be created which will replicate the looks of older staircases. Custom stairs are also a necessity where the house is an unusual shape, the stairs need to be built into an awkward position, or need to make a turn which would be abnormal for pre-fabricated stairs.
