Pros and Cons of a Wallpapered Kitchen Backsplash
Lead Image for Pros and Cons of a Wallpapered Kitchen Backsplash
Installing a wallpapered kitchen backsplash is a fast, economical, and creative way to brighten and add color to your kitchen. Wallpapered Kitchen backsplashes do have their pros and cons, however. Keep reading on to find out about the upsides and downsides of covering your kitchen backsplash in wallpaper.
Pros of a Wallpapered Kitchen Backsplash
Your wallpapered kitchen backsplash will be unique thanks to the wide range of wallpaper styles and patterns available. It is simple to install a wallpapered kitchen backsplash thanks to self-adhesive wallpapers. Compared to tile, stone, laminate, glass, mirrored, or metal backsplash materials, wallpaper is among the most economical choices for a kitchen backsplash.
Color and Design
You can choose from a vast array of wallpapers for your kitchen backsplash. Select a wallpaper that will work with the existing countertop, hardware, and cabinet colors. Take one of your cabinet drawers to the wallpaper shop to help find complementary colors and textures. For a contemporary kitchen choose a mod design with a geometric pattern of circles, squares, or asymmetrical lines. For a country kitchen, select a vegetable, flower, herb, or farm animal motif. In a modern kitchen, apply a clean stripe, dot, or textured surface like grasscloth, linen. If you like, you can choose a design that mimics tile, brick, or stone surface.
Installing Wallpaper on a Kitchen Backsplash
Buy wallpaper for your kitchen that is made for bathrooms, as it will do the best job at resisting moisture and preventing mold buildup. Install the wallpaper over as large a surface area behind the sink, range top, and other appliances as you can. Be sure to cover at least 1/4 of the room's wall area to create a unified appearance. Match patterns carefully when applying the wallpaper, as errors will be magnified in small areas and at corners.
Frugal and Fashionable
You may be able to buy a wallpaper remnant roll to do your kitchen backsplash. Buy at least one yard more than your measured square footage or fitting around corners and between countertops and window ledges to provide for pattern matching.
The downsides of wallpaper as a kitchen backsplash material are low durability and potential difficulty of cleaning stains and splatters off the backsplash.
The durability of Wallpapered Kitchen Backsplash
Even the strongest wallpaper self-adhesive may come loose after repeated exposure to humidity and heat, especially near the stovetop and oven. You can repair peeling wallpaper with waterproof epoxy glue. Allow the glued portions to set for 12 hours before exposing them to heat or moisture again.
Cleaning a Wallpapered Kitchen Backsplash
Even some scrubbable wallpapers may not be able to withstand regular cleaning with harsh cleansers and spray cleaners. The wallpaper may peel or even fade in spots. If you have purchased extra yardage you may be able to replace strips as needed or apply them right over the damaged strips. Prevent spots and stains from forming on your wallpapered backsplash by cooking food in pots with partial or full lid coverage at all times. Wipe down the backsplash behind the kitchen sink frequently to prevent adhesive peel-off.
